IAVC on H22A4
ok i have a problem with my IAVC on my 97 prelude sh. i think that it is clogged due to bad plugs not burning enough fuel. does anyone know where this is located and how i should clean it, thanks
-joe
-joe
If it's a fuel system buildup problem, maybe you could flush it out with sea foam? Check their website, I think they have a little FAQ/infosheet of what sea foam can do and how to do it.
the iac is right in the middle of the intake manifold, when looking at the engine. it has an electrical connector, a coolant line and is held in by two 12mm bolts. Remove it and check the screen on the back, if its is clogged clean the carbon off and reinstall it.
