HOLY SHIT!...My Headlight Switch is Shorting Out!!! 93 EJ1
Old Apr 12, 2004 | 11:34 PM
Simple SOHC's Avatar
Default HOLY ****!...My Headlight Switch is Shorting Out!!! 93 EJ1
Ok...what I read would probobly be a fuse...is probobly not!!! I've been having the problem where my dash lights won't come on all the time unless I wiggle the headlight ****. Well tonight as I was driving...there was a distict smell of burning plastic and electrical fire...followed by my dash lights dimming and the clock switching between bright and dim.
What do I need to fix this and where can I get it? I'm assuming I need the entire turn signal rod of the column. Is there any way to open the switch so I can see whats goin on inside the ****?
I can't go without a car...and I do a big amount of driving at night due to the fact I take night classes...so I need to resolve this tomorrow.
Old Apr 13, 2004 | 06:31 AM
AutoXer's Avatar
Default Re: HOLY ****!...My Headlight Switch is Shorting Out!!! 93 EJ1 (H23 EG Hybrid)
I had the same problem with my car. You need to replace the whole combo switch, but it's one unit, so it's not too bad. Go to http://www.slhondaparts.com/browse.asp, http://www.hondaautomotiveparts.com/ or your local dealer to get the switch. I did it two years ago, so I don't remember how much it was, but I did drive around with the bad switch for a couple of months before it bothered me enough to change it.
Old Apr 13, 2004 | 06:38 AM
2manycars2choose's Avatar
Default Re: HOLY ****!...My Headlight Switch is Shorting Out!!! 93 EJ1 (EX_AutoXer)
Wierd,.. Same thing is happening in my 94 Coupe EX. I turn on the headlights and the interior lights dont come on, so I turn the dimmer low and then up and they come on. Should I be expecting the same problem you guys are talking about?
Old Apr 13, 2004 | 07:01 AM
RedlinedVTEC's Avatar
Default Re: HOLY ****!...My Headlight Switch is Shorting Out!!! 93 EJ1 (2manycars2choose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2manycars2choose &raquo;</TD></TR><TR><TD CLASS="quote">Wierd,.. Same thing is happening in my 94 Coupe EX. I turn on the headlights and the interior lights dont come on, so I turn the dimmer low and then up and they come on. Should I be expecting the same problem you guys are talking about?</TD></TR></TABLE>
My 95 EX does the exact same thing. I assumed it was probably the dimmer switch going bad, but it's the stalk eh? Guess I'll pick one up.
Old Apr 13, 2004 | 08:41 AM
AutoXer's Avatar
Default Re: HOLY ****!...My Headlight Switch is Shorting Out!!! 93 EJ1 (RedlinedVTEC)
Well, mine was the stalk, and it sounds like his is too because I could wiggle the headlight switch and they would come on. Before I replaced it, it got so bad the same thing was happening with the headlights as well. Wiggle your headlight switch to see if it works for you. If not, it may be the dimmer.
Old Apr 13, 2004 | 11:55 AM
Thnx for the replies...I'm goin to go look for one today hopefully. If not...then no driving at night for awhile.
Old Apr 13, 2004 | 12:06 PM
B_CRUZ!'s Avatar
Default Re: (H23 EG Hybrid)
I was just at the junk yard in hayward on saturday and I know for a fact they have quite a few in stock. its the first big one on depo road. I saw a EX one too.
ribs
Jan 25, 2011 04:35 AM
98-DC4
Jan 19, 2007 01:27 PM
MugenHonda
May 30, 2005 08:29 AM
Basically
Mar 6, 2005 08:58 PM
itsallmotor
Mar 19, 2003 06:33 AM
