97 GS colling fan not turning on
Old Apr 12, 2004 | 10:46 PM
BeesDA6's Avatar
Default 97 GS colling fan not turning on
I noticed that my fan does not kick in. Ive tried lettting the car run for 30 mins and the fan still doesnt kick in. my temp guage reads about only a quarter under half. But when I run my A/C both fans will work. Any thoughts ?
Old Apr 12, 2004 | 10:57 PM
3.504's Avatar
Default Re: 97 GS colling fan not turning on (BeesDA6)
may not be gettin warm enough to kick the fan on. drive down the highway on a hot day, then as soon as you get off the highway, let it sit at idle for 5-10 minutes and see if it kicks on. it should kick on after that, should be warm enough. since both fans are kicking on when using AC it sounds all in working order
Old Apr 13, 2004 | 04:08 AM
JimBlake's Avatar
Wait until summer when it's hot enough. The fan isn't supposed to come on until the temperature gauge is around the 1/2 mark.
You could jumper the fan switch to make sure the relay & the rest of the circuit is OK. Then you can take out the fan switch, put it in a pot of water along with a thermometer, & heat it up. Use a continuity tester & watch for it to close.
Old Apr 13, 2004 | 05:36 AM
ebelp's Avatar
Default Re: 97 GS colling fan not turning on (JimBlake)
After 2 years, I have yet to hear my fans cut on. My temp guage never goes past the 1/4 mark either, so I don't worry about it.
brickerj
Dec 22, 2011 02:08 PM
Flatlandz
Honda Civic (2001 - 2005)
May 2, 2010 12:32 PM
kustom_2323
Sep 24, 2009 05:14 PM
Paluce
Mar 20, 2007 09:33 AM
cslegacy
Jan 12, 2007 11:59 PM
