Where to buy OEM honda pins for JDM foglight connector
I got a OEM type R foglight switch on order for my JDM frontend
I got these connectors off a junked car, I use the green for S2000 switch, and (going) to use the yellow one for the JDM ITR foglight switch.
My question is, where can I buy these crimp pins on the right, I only have 3 but need 5, these are the same as the OEM pins used in these connectors.
My friend who works at the local Honda Dealer used to give me these crimp pins, but a Tech complained one day and I can't get them no more
Is there some place else I can buy these crimp pins, I want to make a clean install close to factory if possible, not using them butt connectors.
Thanks!
Thanks!
why not just find another connector from the junked car that you have access to and take it from there? Those pins are used in numerous places in the car including the mirrors and several underdash components.
Yes, but the idea was to get new pins and crimp them, it is kind of hard to re-use crimped pins, hard to open them up and crimp them again... they always fall apart.
BTW, not sure the dealer sells these, they are used in Terminal Repair kit they have at the dealer, a tech complained that my friend were giving them to me so he can't do that anymore.
doubt Radio Shack would have anything like this though....
where else do people go to buy their OEM crimping terminal Pins?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Try another dealer!</TD></TR></TABLE>
You don't have to undo the wire in the crimp. Just cut the wire and solder it to your wiring harness. The OEM crimps are likely to be better than any crimp that you do unless you have the correct crimping tool. Soldering is a lot more repeatable and easier to do.
Black R
Dec 24, 2002 12:19 AM
