oil in throttle body...help.
Old Apr 12, 2004 | 06:46 PM
2stockrocketz's Avatar
Default oil in throttle body...help.
ok i was taking off my air intake and i noticed some oil in the end rubber piece of the intake next to the throttle body there was a little bit of oil in the tb but i dont think it went behind the tb "plate" and i also looked in the intake and it was clean??? any ideas? also what could or would happen if i sucked through some oil???
Old Apr 12, 2004 | 07:12 PM
DaChoZn1's Avatar
Default Re: oil in throttle body...help. (2stockrocketz)
Maybe you over oiled your K&N Fliter? Or it could be from the breather hose that connects to the valve cover
Old Apr 12, 2004 | 09:32 PM
kittedaccord's Avatar
weird ,what kinda filter?and the worst i would think is ur car would burn white smoke til it was all burnt out,u may want to clean it good and then re-check it to c if the oil is still in the tb.
Old Apr 13, 2004 | 10:14 AM
Default Re: oil in throttle body...help. (kittedaccord)
well first off guys thanks for the help. but i think that the oil is from the breather hose because i looked in the intake (pipe and filter) and no oil its only near the breather so can anyone tell me why it would leak out oil and have i been damaging the motor in that condition??
Old Apr 13, 2004 | 06:43 PM
bump
Old Apr 13, 2004 | 07:06 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
only two things I can think of are blow by or your pcv valve is no good.
Old Apr 13, 2004 | 07:48 PM
showgunz's Avatar
Default Re: oil in throttle body...help. (cb7-R)
You might need an oil catch can. Did you drive your car pretty hard recently?
Old Apr 13, 2004 | 09:22 PM
KDKane's Avatar
Default Re: oil in throttle body...help. (showgunz)
it is normal, due to the breather hose(s) ...don't worry about
jrdnwheeler
Sep 3, 2008 08:48 AM
boomersz
Feb 6, 2007 08:19 PM
matix
Sep 19, 2004 10:17 PM
GUNNER666
Jul 12, 2004 08:10 AM
SjCiViCHB
Dec 22, 2001 10:18 PM
