D15B7+nitrous=??? whats the result?
I have my old nitrous kit off from my 93 Prelude VTEC sitting around in my garage. Since i cant get H22A for a while, but i can afford to install nitrous and possiblity convert my single wet kit to a direct port setup. I dont mind making 4 holes in my stock intake mainfold. I can drill and tap a new hole in my CNC machine shop class.
MY question is what can my stock civic do with single wet kit setup? I know my friend who ran 60 shot on his stock D15 setup and dropped a valve. He had stock injectors, stock fuel pump. but b&m fpr setup. he ran low-mid 14's all day with 55 shot. Which he now with new setup runs low 12's
anyways, if i want to run 75 shot on single wet kit, i would need to upgrade the fuel pump, fpr, and would i need to do the injectors too? This motor is going to be out of the car by oct-nov for sure. So i just dont want to spend too much money into that motor.
What about direct port? more safer for the 75 shot setup? change pump, injectors, fpr also?
ahh yeah i remember now seeing my friends rod after he swapped out the rod for a stronger one.. that thing was thin like a toothpick... so i guess ill just stick with 50-55 shot for now... Stock fuel pump ok? and injectors?
you dont even need the tools to tap a mani in a shop class like that take out a drill bit and then take out the 1/8th NTPS tap and tap it and be done with it. 50shot wet will be fine on there i wouldn't go any higher than that though
Better safe than sorry, stick with 55 for now, especially on a D15. Don't be like me, I'm gonna be running a 100 shot on a stock shortblock at the track.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IDriveAHonda »</TD></TR><TR><TD CLASS="quote">Better safe than sorry, stick with 55 for now, especially on a D15. Don't be like me, I'm gonna be running a 100 shot on a stock shortblock at the track.
good luck with all that!!
</TD></TR></TABLE>good luck with all that!!
91integraLSVTEC
Sep 29, 2007 12:42 PM
BlackB18CTeg
Sep 14, 2003 04:43 AM
