cylinder head replacement help
Old Apr 12, 2004 | 05:41 PM
Layziebtnh055's Avatar
Default cylinder head replacement help
what exactly do i have to do to swap my head, is it hard, do i have to take off the lifters and valve spings
Old Apr 12, 2004 | 05:49 PM
Redline130's Avatar
Default Re: cylinder head replacement help (Layziebtnh055)
What kind of motor? If you have a D-series, no you won't have to remove any of the valvetrain. B-series, you will have to remove some of it to access the head bolts. I highly suggest getting a factory manual, http://www.helminc.com
Old Apr 13, 2004 | 04:28 AM
Default Re: cylinder head replacement help (Redline130)
it is a d16 head on a d15 block
Old Apr 13, 2004 | 07:09 AM
tgreaves's Avatar
You dont have lifters.. Since its a d series motor you just take the valve cover off and you will see the head bolts.. There are 2 sensors on the left side of the motor that you will need to unplug.. Pull the dizzy off.. Pull the timing belt off and take it out..
Oh and pull all the stuff of the intake manifold and pull of the exhaust manifold.. I find it eaiser to just pull the head off with the intake still on the head..
EfSedanLove
Apr 10, 2006 03:42 PM
realis9
17
Jan 16, 2006 05:15 PM
SlowTeg
May 22, 2004 04:11 AM
integra6650
Jul 21, 2002 05:40 PM
jdstoledo
Apr 7, 2002 02:35 PM
