is this a great all motor setup for gsr
im thinkin for 2000 gsr, i read that jg edelbrock victor x manifold is great setup with edelbrock 65 mm throttle body, i m curious whats the best camshafts, cams, valve springs,retainers setup,skunk 2 for the most whp gain,will the aem short ram intake in the victor x manifold
quick answers:
dont get te victor-x for all motor. too big.
depending on what you wanna do and use the car for, the rest of yur questions cat be answered
Here's what I'd do to a GSR for a good all motor setup:
JDM ITR tranny
Comptech flywheel
ACT clutch
JDM DC 4-1 header
CTR pistons
Skunk2 Stage 2 cams and valvetrain
RC 310cc injectors
190 lph fuel pump
AEM EMS
Falken Azenis
100 lbs weight reduction
This should have you eating STOCK Evo's for breakfast.
Edit: changed to say "stock".
JDM ITR tranny
Comptech flywheel
ACT clutch
JDM DC 4-1 header
CTR pistons
RC 310cc injectors
190 lph fuel pump
AEM EMS
Falken Azenis
Kendall, you mean stock evo viii's? That is debatable, but yea, thats a nice setup (notice how half of it doesn't even add/free up HP, just makes the best use out of what you have!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">Here's what I'd do to a GSR for a good all motor setup:
JDM ITR tranny
Comptech flywheel
ACT clutch
JDM DC 4-1 header
CTR pistons
RC 310cc injectors
190 lph fuel pump
AEM EMS
Hondata
Falken Azenis
This should have you eating Evo's for breakfast.</TD></TR></TABLE>
Thats a very nice setup.
I would do everything the same except
Toda Header
Toda Cam Gears
If you want a "GREAT ALL MOTOR SETUP".
You definately need some headwork
....DPR Stage 6 headwork
Also, I wouldn't mind having a top of the line TUNER. Thats the key.
Possibly stroke it to a 2.0
If I had a bottomless pit of money, I'd have a hell of a time
JDM ITR tranny
Comptech flywheel
ACT clutch
JDM DC 4-1 header
CTR pistons
RC 310cc injectors
190 lph fuel pump
AEM EMS
Hondata
Falken Azenis
Toda Header
Toda Cam Gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crackerballer »</TD></TR><TR><TD CLASS="quote">Kendall, you mean stock evo viii's? That is debatable, but yea, thats a nice setup</TD></TR></TABLE>
Being that an ITR with bolt-ons, a comptech flywheel and a 4.9 final drive can beat up on stock Evo's, this setup (if properly driven) should be able to hold it's own against Evo's with mild modifications. You may also want to throw in a hundred pounds or so of weight reduction to make sure though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patdemps »</TD></TR><TR><TD CLASS="quote">Thats a very nice setup.
Toda Header
Toda Cam Gears</TD></TR></TABLE>
I was actually going to list those, however I wanted to keep it within a reasonable budget and the Toda header doesn't exactly fall into that budget.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patdemps »</TD></TR><TR><TD CLASS="quote">If you want a "GREAT ALL MOTOR SETUP".
If I had a bottomless pit of money, I'd have a hell of a time</TD></TR></TABLE>
for Dan Paramore Racing, despite the fact that his stage 6 headwork will probably cost about as much as the car did to begin with.
Toda Header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crackerballer »</TD></TR><TR><TD CLASS="quote">Kendall, we are assuming this kid wants it for drag right? But if you did everyhting u said, you could own an evo on the autox. Kendall where you at in NC?</TD></TR></TABLE>
I took it that he was looking for a good "general use" setup, so I listed mods that I think would best suit all motorsports as a whole. I've seen setups very similar to this run consistent low 13 second passes, as compared to a stock Evo (the fastest I've ever seen a stock one run is 13.6). For autocross and road courses, all he should need is a larger rear sway bar, Ground Control's, and Koni Yellow's to have a car that can be effectively competitive. Of course he would need to learn how to properly drive it.
I'm in Hendersonville (i.e. Hendo) which is just South of Asheville in the Western part of the state.
Yes, Dan Paramore's headwork did cost a ton. However, I dyno'd at 190whp without touching my fuel, on ITR cams. It did crazy things for my setup.
I also ran the Toda Header and didn't have cam gears on my ITR cams.
So, there was plenty of room for improvement.
I had to go turbo though. So, I sold the head for a stock GSR head and sold my ITR tranny for a GSR tranny.
Boost
But ill never forget all motor vtec screaming. I had a ton of fun with it. Easily a high 13 second car.
Boost
If I wasn't just starving to keep up with Z06's and the V8's I wouldn't have. But I just feel the urge to test the next level. I've never owned a turbo car, just been in them and known about them. I studied up for a long *** time and did my build up nice and patiently. I can't wait honestly.
The all motor setup was pretty mint. I surprised a ton of people and it had a bunch more potential. However, its just a lot more pricey then just getting all that power at once like you have with boost. I mean I sold my whole setup and basically made all the money for my turbo kit and also got a 98 and up front, rs series sides and rear, cleaned up the look, got some black c8's, and overall think its gonna be nice when I take it out and snap some pics. I spent a ton of time putting this all together and have dealt with a ton of shipping that I wish I would have never done. But all in all, after all this time, I am glad I did it. Over the winter I was hanging myself trying to sell everything, ship everything, buy everything, find good deals and most of all find time for everything with college. Now that its almost done, it was all worth it.
I was going to go with Skunk2 Stage 2's, Toda Cam gears, Chipped ECU at the dyno, Hondata instead of VAFC, tune, tune and tune some more. That was my plans with the all motor setup. I could have done that all over the winter, but I decided turbo was the route I wanted. With that setup I listed above I think I would have easily pushed over 200whp and thats with a stock bottom end. That headwork and header back setup I had was just killer (2.5" cat and 70mm Kakimoto exhaust)....I have video of me in my car racing around and at the drag strip, man it was a pleasure to hear that thing roar in vtec. I mean ROAR. It sounded like a stock car....vtec was mean.
Ill miss it. But ill love turbo.
raverx3m
Jan 26, 2015 05:31 PM
RPMvulocity
42
Oct 25, 2011 09:18 PM
MikeSarr_GSR
Engine Management and Tuning
Jul 1, 2008 06:14 PM
Jimmy
128
Oct 11, 2006 10:00 AM
