please help with mpfi swap
image taken from here:
http://www.fourthgenhatch.com/mpfi.html
very good writeup by fellow member. use it.
Isn't that green plug (which is unused in the picture above) suppose to plug into the EACV? And the white one that is in the EACV in the pic should be the leftover tandem vavle plug right?
pull the hazard fuse for 10 sec to reset any codes, then try and start it again, if you still get the code then take off iat plug,
measure the volts between the red/yel and body ground, there should be 5 volts
measure the volts between the red/yel and grn/wht, there should be 5 volts.
if you passed everything, not its either the sensor or the ecu, so now
measure the resistance between the 2 terminals on the sensor itself, there should be 1-4 ohms. if you pass this test then its probably yoru ecu, replace with a known good ecu
just got back from the shop, found out that all four of my injectors are bad. i took the fuel rail off and no gas game out of injector. so i then can 12volts to injector and i get nothing. does anyone know what would cause all four injectors go bad. im using a resistor, but the first time i wired in the injectors i had the two wires crossed could this cause my injectors to fry. thanks for the help
2fast4udude
May 14, 2006 10:24 AM
FourthGenHatch
11
Apr 27, 2003 04:34 PM
