Is a sealant nessary for a new head gasket?
I saw this at the auto store...and I'm replacing the head gasket on my 97 gsr for the first time...is this nessary?
http://www.jegs.com/cgi-bin/nc...r=361
Modified by GSR4door1 at 8:13 PM 4/12/2004
Not necessary, but it does help some. I use it on every headgasket I install for extra security. Just make sure you let it dry a bit before bolting the head on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 »</TD></TR><TR><TD CLASS="quote">Not necessary, but it does help some. I use it on every headgasket I install for extra security. Just make sure you let it dry a bit before bolting the head on.</TD></TR></TABLE>
Excellent point......Try using the Copper Spray, it is better to be safe and not sorry.
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
It doesn't hurt, just some extra added insurance.
I usually use shelak...
good for heat transfer, holding gasket in place plus fills irregularities..
guess is like the cooper spray... but thicker..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluesi00 »</TD></TR><TR><TD CLASS="quote">hondabond will work on a headgasket?? </TD></TR></TABLE>
I would not use Hondabond on a head gasket because it's so thick, and also I think Hondabond is usually meant for rubber gaskets. It would probably hinder the headgasket from sealing properly.
do NOT use hondabond on your headgasket, its great for the valvecover gasket, not for the headgasket. Anyway, I didnt use any on mine and I havent had any problems yet.
SolAssassin
43
Jun 18, 2008 09:19 AM
crxcess
Apr 6, 2006 05:29 AM
