Broken Clutch, Bent Valves, Random Pics
Cause: This is what happens when you do not adjust your Exedy Organic. Its much worse then the pics show
Effect: Bent Exhaust valves
Bling Bling
Thanks Clayton
Towing the crapper to Payn. Thanks Tom and Devin
AND JOE for the tow
My next kaa
Did you know that the tps and map sensor have the same style of plug
Running good so far. I will be at gman thursday and saturday, hopefully I put everything back together in the right place.
Modified by canuckr at 8:06 PM 4/12/2004
Modified by canuckr at 8:07 PM 4/12/2004
Bling Bling
Thanks Clayton
AND JOE for the tow
My next kaa
How does not adjusting the clutch cause bent exhaust valves??? How did you bend your valves?? What were you doing??
also what can you really do to adjust a clutch
-Larkin who curious and is happy to see the 97' running
-and who also bent valves during the past year
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EbboyPSi »</TD></TR><TR><TD CLASS="quote">How does not adjusting the clutch cause bent exhaust valves???
-Larkin who curious</TD></TR></TABLE>
I thought he was saying the bent valves were because he mixed up the map & tps sensors???
busted clutch=>misshift=>bent valves??? dunno
btw...i am on my 2nd EXEDY clutch and have never had to adjust anything, i am a devoted EXEDY clutch fan/user
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR »</TD></TR><TR><TD CLASS="quote">busted clutch=>misshift=>bent valves??? dunno
btw...i am on my 2nd EXEDY clutch and have never had to adjust anything, i am a devoted EXEDY clutch fan/user</TD></TR></TABLE>
yes. several times
glad to see you are going to be up and running soon, ryan!
yes. several times
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BryanSprinkel »</TD></TR><TR><TD CLASS="quote">A little 3rd to 2nd shift?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N »</TD></TR><TR><TD CLASS="quote">
yes. several times
yes. several times
The Exedy Organic for some reason on itr's need to be adjusted. because the throw-out bearing get pushed into to far. It has been covered here before. I was to lazy to adjust, team lazy yo
I wanted fourth gear, but couldnt get into gear (clutch was just about dead) and I got second gear instead, spun the motor to about 11k, then it just died alittle afterwards.
The tps/map sensor thing, was after a I got everything back together.
Ryan-Who should be studing right now for his statics exam, but cant focus.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canuckr »</TD></TR><TR><TD CLASS="quote">
Ryan-Who should be studing right now for his statics exam, but cant focus.</TD></TR></TABLE>
dammit. I wanted to be able to blame my misshift on the clutch too. Unfortunately, mine went into gear like a hot knife through butter (felt just like 4th)
. I popped it back into neutral after about a millisecond and it was too late. I bent 6 exhaust and 2 intake valves on my R however
[QUOTE=canuckr]
QUOTE]
its ok, ive made the same mistake when i finished building my motor. i though it was my hondata that was flucked up. till i glanced at the helms and noticed that the color of the wires dont match where they go.
i felt dumb
QUOTE]
i felt dumb
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest »</TD></TR><TR><TD CLASS="quote">
i felt dumb</TD></TR></TABLE>
If only we'd been that lucky - it was pretty $$$ for canuckr to have payn figure out waht was wrong
Canuckr - you thank all sorts of people but forget your tow?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">How do you go about adjusting the clutch and why does it need to be adjusted? </TD></TR></TABLE>\\
Clutch adjustment tool. Isn't that to set it at the right distance?
I've never heard of that. I've always just used a clutch alignment tool and while the tool is in there, I bolt everything down. There doesn't seem to be anywhere I can adjust the distance from the pressure plate to the disk or the disk to the flywheel.
I ran into the same problem on my first swap.
Now I've engraved "TPS" and "MAP" in the plugs for future reference.
</TD></TR></TABLE>I ran into the same problem on my first swap.
Someone please explain this "clutch adjustment tool" a little for me.
I've done quite a few clutch installs during my time and never had one kit come with an 'adjustment tool'...I'm curious....
You are not talking about the alignment tool are you? That doesnt change distances between the plate and disc, just centers them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">just centers them.</TD></TR></TABLE>
i think thats all it does.
NO such thing as an clutch adjustment tool, alignment tool is used because the clutch is splinned. You cant "adjust" a hydraulic clutch, I think they are talking about the clutch travel stroke.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">You are not talking about the alignment tool are you? That doesnt change distances between the plate and disc, just centers them.</TD></TR></TABLE>
I think he is. Unless he swapped a cable tranny into his R
With exedy clutches, you need to adjust the push rod on the clutch pedal. This will create more freeplay at the top of the clutch pedal, and create a shorter release bearing travel. This elimanates that scraping or grinding sound when you press the cluth pedal fully to the floor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si »</TD></TR><TR><TD CLASS="quote">With exedy clutches, you need to adjust the push rod on the clutch pedal. This will create more freeplay at the top of the clutch pedal, and create a shorter release bearing travel. This elimanates that scraping or grinding sound when you press the cluth pedal fully to the floor.</TD></TR></TABLE>
Thank you, that is it.
No cable tranny here
WONG FRIED RICE
67
Jul 13, 2006 11:06 PM
pinota
Sep 30, 2002 04:54 AM
