confused : d16a1 vs ZC performance, TURBO BUILDUP
THIS IS FROM RACE ENGINEERING WEB SITE
problem is I thought all D series RODS were the same.
but when I lookup there site I see different rods for d16 then different for d16a1 <---us zc??? 1.6 integra
CR-A93845B CROWER ECONO BILLET ROD : D16 $398 SET
CR-B93726B CRWR BILLET ROD:HONDA 1.6ZC(D16A1) $665 SET
confused, because I thought the d16 ones will fit..and BIG $ DIFF.
then pistons.
JE-181698 JE HONDA 1.6ZC(D16A1):75.5mm/9:1 $124 EA
I take it I have to order the stuff for 1.6ZC(d16a1)??. and is that a .5mm oversized piston?
last question is sleeves, I am going to purchase them from exospeed.com, they are all the same correct?
then pistons.
d16a6 rods will fit fine in the dohc zc, they are the same. that has to be an error on the race engineering website. talk to wil at exospeed.com if you have any questions. if i were you, i'd go through him for your entire engine buildup...IMO exospeed is one of the best companies in the business.
