low rpm miss...
at low rpm's my car is missing.. from 0 to 3000 grand... if i easy into it, it won't miss... and its not in high rpm's so i figured it wasn't my valves.. I was thinking to check my cap in rotor.. if anyone got idea's or suggestions it would be appreciated..
Well instead of "thinking" to check those things, why don't you check the basics first, then, if your problem still persists, proceed to ask specific questions.
Saying stuff like "my car has a miss" is like saying "I don't feel well today"
Both statements can cover a wide array of problems.
ya... Thats why this is jacking me off cuz it could be so many things... I was just looking to see if anyone else had a problem like that.. Im poor and i can't do this trial and error shizzel. when you say check the basics what do you mean, Like what? Help me out..... Thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kchungb17a »</TD></TR><TR><TD CLASS="quote">fuel, spark, compression... the basics. When's the last time you changed the plugs? fuel filter? </TD></TR></TABLE>
yeah try the plugs thats what my car was doin when my plugs were bad
I just put new plugs in... and i added fuel injector cleaner... the cap and rotor look o.k.... I have an Apex'i vtec controller and i have a filling either a wire is coming loose or something ... im about to rip that thing out... I'll
try changing the fuel filter too.. thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UniontownGizzer »</TD></TR><TR><TD CLASS="quote">I just put new plugs in... and i added fuel injector cleaner... the cap and rotor look o.k.... I have an Apex'i vtec controller and i have a filling either a wire is coming loose or something ... im about to rip that thing out... I'll
try changing the fuel filter too.. thanx</TD></TR></TABLE>
Atleast while you are taking this stuff out, inspect it. What did the old plugs look like ? Was there signs of leanness ? richness? incorrect gapping ?
How are the wires ? cracks ? And how did you determine that the cap and rotor "looked ok" ?
You can't just change things and expect it all to work out. You must draw conclusions as to why these things happen. It will help you better understand how you engine works and that will soon lead you to how to make it produce the most HP out of what you do.
try changing the fuel filter too.. thanx</TD></TR></TABLE>Atleast while you are taking this stuff out, inspect it. What did the old plugs look like ? Was there signs of leanness ? richness? incorrect gapping ?
The plugs looked grey... and they looked like i might be running a lil lean.. but i talked to someone at honda and they said that sounds normal... my vtec controller is set at stock settings so it shouldn't be running lean... I'm just going to have to take it to acura tomorrow i guess.. Thanks for all the feed back and help... I really appreciate it..
QWKPHKR
Sep 3, 2002 06:13 PM
