Need directions on how to use throttle body cleaner
Old Apr 12, 2004 | 08:37 AM
imaginary17's Avatar
Default Need directions on how to use throttle body cleaner
How do i use a throttle body cleaner?
Old Apr 12, 2004 | 03:20 PM
95 integra's Avatar
Default Re: Need directions on how to use throttle body cleaner (imaginary17)
Step #1: Pop top
Step #2: Position spray nozzle away from your face
Step #3: Push down on the nozzle
Step #4: OMG dont do it on the car because you'll spray the nasty crap you're trying to clean out straight into the engine.
Old Apr 12, 2004 | 03:53 PM
W.O.P.'s Avatar
Default Re: Need directions on how to use throttle body cleaner (95 integra)
take off intake
with car off spray for 10 sec against butterfly
turn car on
move the butterfly manually as you spray in 10 sec incriments
use whole bottle
these are directions straight off my gumout throttle body cleaner can
but dont take my word for it
Old Apr 12, 2004 | 05:00 PM
IVI's Avatar
IVI
Default Re: Need directions on how to use throttle body cleaner (dohc VTEC eaaater)
get the one for fuel injected motors. take off the intake. spray it all over the butterfly... put the straw on the can, and spray it past the butterfly while opening the throttle. you must keep the engine at high throttle to prevent it from stalling out. its easier done with a friend who can maintain the throttle from the accelerator. dont worry about getting all that black sut substance int he motor, the spray will make it combust out of your motor. look into seafoam also.
search on honda-tech. i seen someone have a DIY for seafoam.. it seems like it cleans with all that smoke it generates.
ILS_09
Aug 31, 2009 11:21 AM
tomegun123
Mar 13, 2006 06:39 PM
vtecdc2
May 5, 2002 06:30 AM
mickey513
Apr 9, 2002 10:47 AM
