b18c5 into a sol. parts list....
Old Apr 12, 2004 | 08:11 AM
jbell's Avatar
Default b18c5 into a sol. parts list....
hey. im trying to find out what parts i need for this swap.
i can't decide if i should buy the complete change over or just the motor/tranny/ecu from hmotorsonline.
basically i know i need:
block
tranny
b18c5 ecu
del sol vtec shift linkage
del sol vtec gauge cluster (goes to 8k redline where as the c5 revs to 8400 iirc)
some mounts (thinking hasport... anyone want to reccomend?)
now.. what axles do i need, and am i missing any other parts?
i tried searching, but the results are just too much.. i sorted through them for a good 20 minutes, but to no avail.
thanks to anyone who read through this and will help me.
Old Apr 12, 2004 | 08:16 AM
toolowsol's Avatar
Default Re: b18c5 into a sol. parts list.... (jbell)
You can use stock b18c5 mounts, or aftermarket, doesn't matter, and axles, you need b-series axles, like from a civic si, del sol vtec, integra etc etc..
Old Apr 12, 2004 | 08:21 AM
jbell's Avatar
Default Re: b18c5 into a sol. parts list.... (toolowsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol &raquo;</TD></TR><TR><TD CLASS="quote">You can use stock b18c5 mounts, or aftermarket, doesn't matter, and axles, you need b-series axles, like from a civic si, del sol vtec, integra etc etc..</TD></TR></TABLE>
sweet. thanks for the quick reply.
i guess by this thread you see what i've decided to drop into the sol. should be here soon...
so i should just get ahold of del sol vtec axles and shift linkage. and maybe some Energy Suspension inserts...
Old Apr 12, 2004 | 08:23 AM
toolowsol's Avatar
I would just get the complete changeover, then buy the right shift linkage
Old Apr 12, 2004 | 08:26 AM
jbell's Avatar
the complete changeover will have the right axles and mounts i assume?
Old Apr 12, 2004 | 08:39 AM
toolowsol's Avatar
yes
Old Apr 12, 2004 | 09:45 AM
jbell's Avatar
sweet.
so now...
just get the complete change over
get a vtec shift linkage
mount inserts
and i should be good to go? i kno wi need to run 2 wires for vtec since its a s model, but what about obd conversion? will i need to do that?
Old Apr 12, 2004 | 09:49 AM
Aber's Avatar
Depends on what year sol it will be going into. If you're putting it into OBD1. You'll need an OBD1 Dizzy. But besides all the OBD1/OBD2 stuff, you're paying $400 for axles and mounts from Hmotors pretty much, because the linkage is useless to you.
Old Apr 12, 2004 | 09:51 AM
Sector9guy's Avatar
Default Re: (Aber)
Also, depending on what model sol it is, you'll need an ITR throttle cable, i doubt most swaps come with it. inlinefour.com has em for $25 or so.
Old Apr 12, 2004 | 10:00 AM
jbell's Avatar
Default Re: (Aber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aber &raquo;</TD></TR><TR><TD CLASS="quote">Depends on what year sol it will be going into. If you're putting it into OBD1. You'll need an OBD1 Dizzy. But besides all the OBD1/OBD2 stuff, you're paying $400 for axles and mounts from Hmotors pretty much, because the linkage is useless to you.</TD></TR></TABLE>
wait, i dont understand what you mean by "you're paying $400 for axles and mounts from Hmotors pretty much, because the linkage is useless to you."
Old Apr 12, 2004 | 10:07 AM
Aber's Avatar
Default Re: (jbell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbell &raquo;</TD></TR><TR><TD CLASS="quote">
wait, i dont understand what you mean by "you're paying $400 for axles and mounts from Hmotors pretty much, because the linkage is useless to you."</TD></TR></TABLE>
the complete change is 4500, the tranny, motor, ecu package is 4100, the difference between the two is the complete has axles with halfshaft, ITR shift linkage (which you cant use), and mounts. The mounts and axles can be had for roughly $175-$225
Old Apr 12, 2004 | 10:14 AM
jbell's Avatar
Default Re: (Aber)
the complete change is 4500, the tranny, motor, ecu package is 4100, the difference between the two is the complete has axles with halfshaft, ITR shift linkage (which you cant use), and mounts. The mounts and axles can be had for roughly $175-$225</TD></TR></TABLE>
so then get the tranny motor and ecu package... and then get the shift linkage, axles and half-shaft from a vtec sol, motor mounts from where and then im good to go?
Old Apr 12, 2004 | 10:16 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (jbell)
i have a del sol VTEC shift linkage for sale if you're interested.
Old Apr 12, 2004 | 10:18 AM
Aber's Avatar
Default Re: (jbell)
so then get the tranny motor and ecu package... and then get the shift linkage, axles and half-shaft from a vtec sol, motor mounts from where and then im good to go?</TD></TR></TABLE>
Yes. The only thing you'll have to address is OBD1/OBD2. Do you have a new sol?
Old Apr 12, 2004 | 10:31 AM
.hugo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbell &raquo;</TD></TR><TR><TD CLASS="quote">but what about obd conversion? will i need to do that?
if you have a 93-95 sol you'll be fine as long as you get a obd1 motor
Old Apr 12, 2004 | 11:05 AM
jbell's Avatar
Default Re: (Aber)
im not sure what years the obd switched in the sols.
Old Apr 12, 2004 | 11:06 AM
jbell's Avatar
Default Re: b18c5 into a sol. parts list.... (starang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by starang &raquo;</TD></TR><TR><TD CLASS="quote">
if you have a 93-95 sol you'll be fine as long as you get a obd1 motor</TD></TR></TABLE>
do they make an obd1 b18c5?
Old Apr 12, 2004 | 12:02 PM
AzntaggeR's Avatar
TSPeed Factory
all honda makes switched to obd2 in 96. if you get a b18c5 it will be an obd2. you don't have to get axles or intermediate shaft from a del sol VTEC. i used GSR axles and intermediate shaft in my del sol.
Old Apr 12, 2004 | 12:27 PM
jbell's Avatar
Default Re: b18c5 into a sol. parts list.... (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR &raquo;</TD></TR><TR><TD CLASS="quote">all honda makes switched to obd2 in 96. if you get a b18c5 it will be an obd2. you don't have to get axles or intermediate shaft from a del sol VTEC. i used GSR axles and intermediate shaft in my del sol.</TD></TR></TABLE>
if you used the gsr ones, the type r should fit.. right?
oh, and for obd2 to obd1 conversion, this should work, right? http://cgi.ebay.com/ebaymotors...=WDVW
Old Apr 12, 2004 | 12:35 PM
AzntaggeR's Avatar
TSPeed Factory
oh, and for obd2 to obd1 conversion, this should work, right? http://cgi.ebay.com/ebaymotors...=WDVW</TD></TR></TABLE>
yes and yes ...if you get the obd1 conversion harness you will also need an obd1 ecu.
Old Apr 12, 2004 | 12:55 PM
jbell's Avatar
yes and yes ...if you get the obd1 conversion harness you will also need an obd1 ecu.</TD></TR></TABLE>
what obd1 ecu can i use that will work with the c5?
Old Apr 12, 2004 | 01:55 PM
jbell's Avatar
bump.
along with the above question, what gauges can i use, vtec cluster?
Old Apr 12, 2004 | 03:22 PM
AzntaggeR's Avatar
TSPeed Factory
you can go ahead and run a rechipped p28 (92-95 civic sohc vtec). that's what i'm running with my GSR swap.
you can use a VTEC gauge cluster if you want. or you can just do it the cheap way and use your S or SI gauge cluster and buy indiglo gauges for a del sol VTEC that shows an 8000 RPM redline.
Matt Kotyk
Jan 26, 2013 01:32 PM
BoostedEgHatchFl
Dec 21, 2005 10:31 AM
ubercerealkiller
Mar 30, 2005 03:45 AM
90civichb
Jul 13, 2004 11:40 AM
vain
Jul 13, 2003 04:04 PM
