94 GSR secondary butterflies help??
Old Apr 12, 2004 | 08:07 AM
tiresmoke's Avatar
Default 94 GSR secondary butterflies help??
How do I wire these up? I have the P72 GSR ecu I just need to know how to wire up the sensor under the intake manifold. what ECU pinout do I go to?
Old Apr 12, 2004 | 08:21 AM
APEX CRX's Avatar
Default Re: 94 GSR secondary butterflies help?? (tiresmoke)
A17 PIN
Old Apr 12, 2004 | 08:26 AM
VTECVillain's Avatar
The IAB uses a round 2 prong connector plug. The color coding will depend on the engine harness you use. If you used the GSR harness you will connect PNK/BLU to A17 and the YEL/BLK to any 12V+ YEL/BLK wire from the IACV, injectors, etc - these all go to the 12V+ ECU pinouts A25 and/or B1. If you used the stock harness or one that doesn't have a plug for the IAB, you need to add the plug. Just use any standard round 2 prong connector plug and wire it up the same way.
kevinoneill
Dec 19, 2010 12:20 PM
fibereater
May 5, 2010 10:10 AM
Monkey Fing a Coconut
May 28, 2005 06:58 PM
Si-Yaaa!
Jun 20, 2003 10:45 AM
