I DESPERATELY need help with my brakes!!
The rear brakes on my wifes 88 CRX Si are completely worn out. What I want to do is take the rear brakes off my 93 Civic cx and put them on the CRX.
I can get a good deal on 2nd generation Integra rear disc setups and would like to put a set on my 93 H/B.
Is all of this going to work or am I barking up the wrong tree?
Thanks in advance.
Colin
sure they will...either way...just do a complete swap...means everything minus the LCAs
you can also bolt on 90-00 integra brakes on the crx or civic, all parts will be needed complete trailing arms with the necessary parts, brake lines, e-cables....
http://www.geocities.com/tjsite/rrdisc.htm
I'm not sure if the 2nd gen teg brakes will work or not. you can just get a set of rear disc brakes from a 92-95 si (ex) those would definately drop right in.
Canadian Hybrid
Oct 28, 2001 04:52 PM
