Clutch Problem??
I have a 94 honda accord and just replaced the master cylinder. The clutch sticks in the up position until I tap it pretty hard. Then it functions normal. This only happens when I first get in the car after it sits for a while. Any suggestions on a problem. Thank you for any input.
Phill
Phill
did you also replace the slave cylinder? it is recommended that it is to be replaced at same time with the clutch master cylinder
It could be air in the system - maybe if you bleed it again, it will help, perhaps after you replaced the slave cylinder, if you have not done it yet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by James »</TD></TR><TR><TD CLASS="quote">it is recommended that it is to be replaced at same time with the clutch master cylinder
where does it say this??
