Just pulled CEL #67 from my wife's accord
Old Apr 11, 2004 | 08:52 PM
brcivic411's Avatar
Default Just pulled CEL #67 from my wife's accord
This code is : 67 Catalyst System Efficiency System below threshold, bad catalytic converter
Any hints as to what to try besides getting a new cat? Could it be the 2nd O2 sensor?
Old Apr 12, 2004 | 06:58 AM
JimBlake's Avatar
Default Re: Just pulled CEL #67 from my wife's accord (brcivic411)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brcivic411 &raquo;</TD></TR><TR><TD CLASS="quote">... Could it be the 2nd O2 sensor?</TD></TR></TABLE>Could be, since it uses that 2nd O2 sensor to measure how the cat is working.
Old Apr 12, 2004 | 02:12 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brcivic411 &raquo;</TD></TR><TR><TD CLASS="quote">This code is : 67 Catalyst System Efficiency System below threshold, bad catalytic converter
Any hints as to what to try besides getting a new cat? Could it be the 2nd O2 sensor?</TD></TR></TABLE>
Most likely a bad cat if there is no o2 sensor code with it.
Old Apr 12, 2004 | 04:48 PM
brcivic411's Avatar
Default Re: Just pulled CEL #67 from my wife's accord (Chiovnidca)
any suggestions on where to get a cheap replacement? Don't need high flow or anything like that.
Thanks
Old Apr 12, 2004 | 05:21 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brcivic411 &raquo;</TD></TR><TR><TD CLASS="quote">any suggestions on where to get a cheap replacement? Don't need high flow or anything like that.
Thanks</TD></TR></TABLE>
It may be covered under warranty depending on year and mileage.
Old Apr 13, 2004 | 08:24 AM
brcivic411's Avatar
unfortunately, it's not under warranty anymore. It's a 98 with too many miles and we didn't get extended coverage.
I have no problem swapping it out myself, just want to find a good deal on one.
Old Apr 13, 2004 | 08:43 AM
JimBlake's Avatar
Check your warranty book. Certain 'emmissions equipment' is covered much longer than the normal warranty.
8 yr / 80k miles???
Old Apr 13, 2004 | 01:37 PM
Chiovnidca's Avatar
Default Re: Just pulled CEL #67 from my wife's accord (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Check your warranty book. Certain 'emmissions equipment' is covered much longer than the normal warranty.
8 yr / 80k miles???
Yea, I forgot to mention that. The cat should be covered 8 or 80.
Old Apr 14, 2004 | 11:00 AM
brcivic411's Avatar
i'll check the book tonight.. but the car already has over 80K, so if it is 8/80 then I'm out of luck
Old Apr 14, 2004 | 11:24 AM
brcivic411's Avatar
The best price I've found so far is ~ $150 for a replacement
sickofitall1113
Jun 11, 2007 10:20 AM
chomorro
Jun 26, 2006 10:24 AM
AustinGT
May 9, 2005 03:43 PM
Ge.ES.AHH
Oct 10, 2004 11:21 PM
