2000 spec B16A into 1996 Civic CX
Old Apr 11, 2004 | 08:23 PM
EG2 SiR's Avatar
Default 2000 spec B16A into 1996 Civic CX
I've searched and searched, but cannot find a write up on this.... It MUST exist... Can someone please point me in the right direction? I have all type of questions.... like will it matter that I don't have a place to plug the crank sensor into a usdm harness... or will it make a difference since the JDM ecu will be used.... Anyway any help would be much appreciated... HONDA-TECH, DON'T FAIL ME NOW!!!!!
TIA
Old Apr 11, 2004 | 09:15 PM
JdM_y0's Avatar
failed, sorry
Old Apr 11, 2004 | 09:58 PM
jumpmann23's Avatar
From: Your really lame if you dock my points, WA, 98033
Default Re: 2000 spec B16A into 1996 Civic CX (EG2 SiR)
i have a 00 b16a2 in my 96 dx..
i used a 96 ex harness and pretty much everything was plug and play. i did not have to wire up the IACV or add vtec ect.. it was all done already. but i also used a jumper harness and i am now running obd1 through a chipped p28 so the crank angle sensor was not a issue neither was the secondary 02 sensor.
But for the best write up on this swap id suggest searching under Katman for EK b series wireing info. good luck
Old Apr 11, 2004 | 11:44 PM
Kusai.Nihonjin.Desu's Avatar
Default Re: 2000 spec B16A into 1996 Civic CX (Jumpmann23)
My roommate's about to do this swap...I just wanted to subscribe to it...carry on.
Old Apr 12, 2004 | 08:51 AM
EG2 SiR's Avatar
more specifically than just getting it running.. I need it to pass a state ref inspection to get the all mighty BAR cert..... I am going to use the JDM P2T ecu, that will not look for the crank sensor (I will make it look like it is plugged in so the ref doesnt say antything about it) It would be sooooo much easier to do if the damn harness came out of the engine bay (like obd-1 EG's and what not)
Old Apr 12, 2004 | 09:23 AM
EG2 SiR's Avatar
Come on.... Anyone? just throw out useful information about this swap!!!!
Old Apr 12, 2004 | 09:26 AM
soundbomber's Avatar
don't you need to run a usdm ecu for bar certification purposes?
Old Apr 12, 2004 | 09:29 AM
EG2 SiR's Avatar
Default Re: 2000 spec B16A into 1996 Civic CX (soundbomber)
You are, but the ECU out of a 99-00 civic SiR is a P2T... Just like a USDM Si.... I've been talking with a local ref... and a guy at a honda dealer... I'm told they will not know, or be suspicious of anything, just as long as no CEL's show up....
Old Apr 12, 2004 | 05:53 PM
EG2 SiR's Avatar
bump cause the motor is going in tomorrow.
Old Apr 12, 2004 | 06:57 PM
EG2 SiR's Avatar
bump for my not knowing OBD-II ****.
Old Apr 12, 2004 | 09:30 PM
EG2 SiR's Avatar
damn man... up again.. .someone please... I see more bullshit posts in here get more responses that my legit topic....
Old Apr 13, 2004 | 03:18 PM
ruthless013's Avatar
make sure your diagnostic port works, which may not if you do not have a usdm computer. that's one of the firts tests they run, and they won't proceed any further if you don't have that. have the car smogged as is, if it still has the original motor in it.
Trunks1331
Nov 24, 2012 10:26 AM
Anti-Drama Queens
Jul 19, 2009 09:28 PM
ben1284
Apr 16, 2008 07:06 AM
stealth_EK4
May 5, 2005 08:09 AM
EG2 SiR
Apr 19, 2004 09:24 PM
