95 B18C1 SWAP IN A 94 EX CIVIC
Old Apr 11, 2004 | 04:16 PM
NIGHTCRAWLER94's Avatar
Default 95 B18C1 SWAP IN A 94 EX CIVIC
WHAT DO U HAVE TO WIRE UP IN A 95 B18C1 IN A 94 EX CIVIC COUPE
USING P72 ECU AND B18C1 ENGINE WIRING HARNESS
Old Apr 11, 2004 | 04:28 PM
B_CRUZ!'s Avatar
Default Re: 95 B18C1 SWAP IN A 94 EX CIVIC (NIGHTCRAWLER94)
knock sensor. and switch a17 and a20 at the plugs.
Old Apr 11, 2004 | 04:33 PM
diearzte2
Guest
Posts: n/a
I think your keyboard is broken. Might wanna have that looked at.
Old Apr 11, 2004 | 04:39 PM
is the knock sensor the only thing i got to wire up someone said sumthin bout wiring IAB and sumthin bout the O2 sensor
Old Apr 11, 2004 | 04:48 PM
B_CRUZ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NIGHTCRAWLER94 &raquo;</TD></TR><TR><TD CLASS="quote">is the knock sensor the only thing i got to wire up someone said sumthin bout wiring IAB and sumthin bout the O2 sensor</TD></TR></TABLE>
if you have a four wire o2 in there on your sohc motor, don't worry about it. If you don't then you gotta wire that up too. IAB is wired. you just have to switch the A17 and A20 wires at the plugs.
-B &lt;--- who is on his third GS-R civic.
Old Apr 11, 2004 | 04:52 PM
mario82686's Avatar
From: Between San Diego and the OC, SOCAL, United States
Put a B18c5 into a CRX and you will come to one hell of a fast car!
Old Apr 11, 2004 | 04:53 PM
Default Re: 95 B18C1 SWAP IN A 94 EX CIVIC (b cruz)
cool man thanks any other advice that u can give, appreciated
TerrenceDinesen
May 8, 2012 07:08 PM
EG civic
Jun 17, 2006 10:05 PM
oneslowsohc
Feb 15, 2005 09:35 AM
ZaxEG
Oct 2, 2003 07:35 PM
SuperCivic26
Apr 16, 2003 09:26 PM
