over heating problem help!
Old Oct 27, 2001 | 05:54 PM
ToneyTigre's Avatar
New User
Default over heating problem help!
my previous radiator was punctured and so I bought another one from radiator.com. now that i just put it on; my car still overheats. wtf is going on?? i made sure nothing was leaking. went out and bought new screw type hose clamps. what else did i forget to do?? the installation was very straight forward. i dunno if i did anything wrong or the new radiator is just a peice of crap.
Old Oct 27, 2001 | 10:35 PM
ToneyTigre's Avatar
New User
Default Re: over heating problem help! (ToneyTigre)
also.. im hearing bubbling sounds after i turn the ignition off.
Old Oct 27, 2001 | 11:20 PM
Backyard Speical's Avatar
did you get all the air out of the motor when you install your new baby?
Old Oct 27, 2001 | 11:29 PM
ToneyTigre's Avatar
New User
Default Re: over heating problem help! (Prodigy 2.2 EK)
how do you get the air out??
Old Oct 28, 2001 | 01:56 AM
from the thermosta (spelling) ... i beleive is a 10mm or 12 mm socket. and just open it up and let all the air out. till you see the water shots up without any air in it (it looks like a stright line)
Note: remember to fill back the water that you lose from it.
hope i helped
Old Oct 28, 2001 | 05:06 AM
rioninja's Avatar
It also might not be the radiator. You might have a bad water pump, leaking headgasket, stuck thermostat, etc. Overheating problems suck.
Old Oct 28, 2001 | 07:19 AM
rainforest's Avatar
Default Re: over heating problem help! (RioNinja)
Also check your radiator cap. Did you get a new one with your new radiator.
Old Oct 28, 2001 | 11:44 AM
ToneyTigre's Avatar
New User
Default Re: over heating problem help! (rainforest)
problem fixed.
first off i'd like to say that the radiators from http://www.radiator.com suck. it is cheap in quality and i had to use some of my innovation to make the fan fit and the hose connecting tight enuff. Turns out the connector to the radiator hose was slightly smaller, cause coolant to leak out. By the time i noticed it and got new clamps much of my coolant was gone. I did not anticipate the low on coolant factor. and so that was the cause of my car overheating. i filled additional coolant while engine ran with heat on. imy car no longer over heats. thank you guys for your help.
FYI: did you know hose clamps from honda dealer costs $7.99??!! i found better screw type ones at OSH for 99 cents each.
[Modified by ToneyTigre, 12:48 PM 10/28/2001]
Ek9_Cuhzz
12
Nov 3, 2010 02:35 PM
chikin pickle
Sep 17, 2009 02:59 PM
martiw2
Oct 26, 2008 08:10 AM
Shintakun
Honda Civic (2001 - 2005)
Jan 26, 2008 07:44 PM
streetracerof06
Dec 8, 2005 03:03 PM
