How do I disengage VTEC
Old Oct 27, 2001 | 04:49 PM
Reverend's Avatar
Default How do I disengage VTEC
without throwing a CEL?
Old Oct 27, 2001 | 04:52 PM
Ekliptix's Avatar
New User
Default Re: How do I disengage VTEC (Reverend)
I think you would have to get a customly programed chip. Why would you want to desengage your VTEC?
Old Oct 27, 2001 | 05:14 PM
Jesse H's Avatar
Default Re: How do I disengage VTEC (Ekliptix)
I think so too.
Or unless you have a VTEC controller, and set it to past your redline. I'm still curious how the GS-R feels with just the low cam. I bet it's still slightly faster than an LS.
Old Oct 27, 2001 | 08:25 PM
neo1z's Avatar
Default Re: How do I disengage VTEC (Jesse H)
when i read your post i think a tear fell from my eye.......and the piercing thought........."why?"
Old Oct 27, 2001 | 08:34 PM
PureTeg420's Avatar
Disengage the vtec solenoid and find out. And it's gonna be slower then an LS that's for sure.
Old Oct 27, 2001 | 09:40 PM
Reverend's Avatar
Default Re: How do I disengage VTEC (PureTeg420)
Maybe I should explain why I want to do this . ..
I have a 2000 gsr with an F-max turbo kit, and it leans out really bad (I think) when vtec engages. Then it leans out even worse when the secondary butterflies open up. I was thinking that the valve overlap might be a bit much until I can afford to get a hondata with some big injectors and a full motor build.
EDIT: -- This thread should explain it all.
https://honda-tech.com/zerothread?id=82931
[Modified by Reverend, 12:41 AM 10/28/2001]
Old Oct 27, 2001 | 09:44 PM
MiraiZ's Avatar
vtec contoller is the safest and troublefree way..
Old Oct 27, 2001 | 09:47 PM
Reverend's Avatar
Default Re: How do I disengage VTEC (MiraiZ)
Which one, though? The VAFC threw a CEL when used in conjunction with the MF2 AIC
All these acronyms are starting to sound very military to me. lol
Old Oct 27, 2001 | 09:49 PM
MiraiZ's Avatar
I use Rspec...it doesn't have any fancy fuel mapping programs in it...just a plain jane VTEC controller...works well!!
http://www.r-spec.com/ele/vtec/vtec.html
Old Oct 27, 2001 | 10:29 PM
OneThirtyEight's Avatar
want to disengage your vtec? buy an LS
[Modified by 97blackteg, 2:30 AM 10/28/2001]
Old Oct 27, 2001 | 10:35 PM
MrBite's Avatar
Default Re: How do I disengage VTEC (97blackteg)
Hah I was gonna say "Let off the throttle"
Old Oct 28, 2001 | 09:00 AM
Tomakit's Avatar
Default Re: How do I disengage VTEC (MrBite)
So i just swapped in a b18c1 into my teg, where a b18b1 used to reside. Since I haven't had time to do the wiring (school is hella busy) ive been running around on just the low cam.
No, its not faster than an LS, and sure is reluctant to pull to 8k.
Tom
(who hopes he can get the wiring done this week)
Old Oct 28, 2001 | 10:15 AM
Jesse H's Avatar
Really? That really suprises me considering the the B18C has better flowing heads and the GS-R tranny is tighter. Of course one wouldn't be shifting at 8K anymore since that'll probably land you outside the power peak in the next gear.
Now I've got something to do next time I've got time to kill.
Old Oct 28, 2001 | 10:20 AM
it will stay on the bitch cam. thats why.
Old Oct 28, 2001 | 10:39 AM
Prelussion's Avatar
I have an LS and i'll switch heads with you if you'd like!
Old Oct 28, 2001 | 11:23 AM
Jesse H's Avatar
Um...I know how VTEC works. Thanks.
But even with the so called "bitch" cam, I figured it would be comparable if not quicker than an LS.
I'll just have to try it and see.
Old Oct 28, 2001 | 02:30 PM
vtcntgragsr's Avatar
New User
You wanna know a GSR on only low cam? Just rev the engine before it's at operating temperature. The VTEC solenoid doesn't operate if the engine is cold.
Old Oct 28, 2001 | 05:05 PM
Reverend's Avatar
Default Re: How do I disengage VTEC (vtcntgragsr)
can't do that with a turbo
Old Oct 28, 2001 | 07:38 PM
PureTeg420's Avatar
can't do that with a turbo, shouldn't do that period. The oil is too thick for any car to be revving when it's cold. It's like the quote of the guy who said "make sure your car is cold when you race, cause the transmission shifts harder" or somethin like that...
Old Oct 28, 2001 | 08:24 PM
odb1gsr's Avatar
New User
why don't you just disconnect the solenoid?
Old Oct 28, 2001 | 08:33 PM
Jesse H's Avatar
I'm also not a f*cking idiot.
Where are these nibblenut responses coming from? Geez.
Old Oct 28, 2001 | 08:56 PM
FAST94GSR's Avatar
New User
Instead of disconnecting the vtec solenoid, why dont' you:
a) get bigger injectors
b)up your fuel press
c)richen it up with a vafc
Disconnect the vtec makes no sense whatsoever!!
Old Oct 28, 2001 | 09:15 PM
DOHC_VTEC786's Avatar
New User
Default Re: How do I disengage VTEC (FAST94GSR)
If you unplug your gauge cluster i think you lose VTEC
Old Oct 28, 2001 | 10:04 PM
ITR 2K's Avatar
Pop your hood, and disconnect the VTEC selnoid harness. It's right next to the distributor.
Old Oct 29, 2001 | 04:45 AM
TRM04's Avatar
Default Re: How do I disengage VTEC (ITR 2K)
Listen to these guys. Diconnect the Solenoid...it works and will not throw any CELs. But this is not the correct fix for your problem.
