pin locations for vtec
I just put the p28 in my 94 dx for my mini me ,It is flashing 21,22 which is for vtec I was wondering were to put the wires in the ecu harness,what pin location,I would appreciate any help!
hey man key note , look in the uppermost portion of your monitor and hit that big red X .
no really do a search man there are numerous topics on this and the last we need is another
Please search next time - this info is all over the place if you'd only search.
OBD1
A1-INJ1 INJ1
A2-INJ4 INJ4
A3-INJ2 INJ2
<FONT COLOR="red">A4-VTS VTEC solenoid</FONT>
A5-INJ3 INJ3
A6-PO2SHTC O2 sensor (heating element)
A7-FLR1 fuel pump
A8-empty
A9-IACV IAC valve
A10-empty
A11-empty
A12-FANC engine coolant temp switch
A13-MIL MIL (check engine light)
A14-empty
A15-ACC (a/c compressor clutch)
A16-ALT C alternator
A17-IAB IAB Solenoid
A18-empty
A19-**
A20-PCS EVAP purge control solenoid
A21-ICM ICM
A22- *per Sander* Ignitor
A23-PG1 ground
A24-PG2 ground
A25-IGP2 to main relay and to gound for o
A26-LG1 gound
B1-IGP2 to pin A25
B2-LG2 ground to shields for CYP & TDC
B3-**
B4-**
B5-ACS a/c switch
B6-empty
B7-**
B8-PSPSW PSP switch
B9-STARTER SIGNAL starter signal
B10-VSS vehicle speed sensor
B11-CYP P CYP -P
B12-CYP M CYP -M
B13-TDC P TDC -P
B14-TDC M TDC -M
B15-CKP P CKP -P
B16-CKP M CKP -M
D1-VBU Back Up Power
D2-BKSW brake switch
D3-KS Knock Sensor
D4-SCS service check connector
D5-empty
<FONT COLOR="red">D6-VTM VTEC pressure switch</FONT>
D7-TXD/RXD (data link connector)
D8-empty
D9-ALT F alternator
D10-ELD electric load detector
D11-TPS TPS Signal
D12-**
D13-ECT ECT sensor
D14-PHO2S O2 sensor
D15-IAT IAT sensor
D16-VREF VREF
D17-MAP Map Signal
D18-**
C19-VCC1 MAP 5V
C20-VCC2 TPS 5V
C21-SG1 MAP GND
C22-SG2 TPS GND
OBD1
A1-INJ1 INJ1
A2-INJ4 INJ4
A3-INJ2 INJ2
A5-INJ3 INJ3
A7-FLR1 fuel pump
A8-empty
A9-IACV IAC valve
A10-empty
A11-empty
A14-empty
A18-empty
A19-**
A21-ICM ICM
A23-PG1 ground
A24-PG2 ground
A26-LG1 gound
B1-IGP2 to pin A25
B3-**
B4-**
B5-ACS a/c switch
B6-empty
B7-**
B8-PSPSW PSP switch
B11-CYP P CYP -P
B12-CYP M CYP -M
B13-TDC P TDC -P
B14-TDC M TDC -M
B15-CKP P CKP -P
B16-CKP M CKP -M
D3-KS Knock Sensor
D5-empty
D8-empty
D9-ALT F alternator
D11-TPS TPS Signal
D12-**
D13-ECT ECT sensor
D14-PHO2S O2 sensor
D15-IAT IAT sensor
D16-VREF VREF
D17-MAP Map Signal
D18-**
C19-VCC1 MAP 5V
C20-VCC2 TPS 5V
C21-SG1 MAP GND
C22-SG2 TPS GND
chancock
Sep 17, 2007 01:41 PM
