Seat size comparison: Recaro SPG vs. Bride Zeta II?
Does anyone have experience sitting in both seats?
I sat in a SPG this afternoon, and was wondering if the Zeta II was of equal size or smaller??
the zeta II is tighter than the SPG
btw...bride does not sell the zeta II anymore, theres a newer version called the zeta III which is 10mm wider the the zeta II
just for reference, the seat width of the recaro spg at the base is 395mm. i don't know the width for the brides however.
overall, the spg is pretty snug...i'm 5'4" ~ 140lbs.
hope that helps.
kepani
hope that helps.
kepani
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmEL »</TD></TR><TR><TD CLASS="quote">totally off topic, but what is a good seat for a 180lbs
6'4 guy? wide shoulders? </TD></TR></TABLE>
Recaro carbon-kevlar bucket from the SpiritR (Type A) RX7
I'm 6'1" (185lbs) and it fits great...now all i need is a bracket to mount the damn thing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR »</TD></TR><TR><TD CLASS="quote">the zeta II is tighter than the SPG
correct...zeta 2 is awesome, I'm 130 5'8 waist=31, it's like this seat was made for me. Took me 2 months to track down one zeta 2 last summer and got rapped 1060 for the fiberglass edition with all mounting hardware.
Zeta 3's base is 10mm larger.
I guess it's the fatty american version.
Guest
Posts: n/a
A good affordable seat (as comapred with that carbon/kevlar take get a bank loan or excellent credit card seat ) is the Recaro Pole Position.
It offers slightly lower sides vs. the Bride for easy in-and-out transitions on your daily driver (if be the case). And its la-z-boy wide for use with non-JDM spec 6'+" bodies.
Im 6'2". 195lbs, 34" waist
My only complaint is that the wedge engineering and recaro brackets are not as nice as the Bride mounts. I would actually look for a Bride next time, but with lower sides. My buddies Zeta 3 in his Type R is so high and narrow I can barely get in, let alone twist my leg so that I can actuate the clutch pedal.
Furthermore, since you are 6'4", I hope you do not have a sunroof (being the Type R forum, unlikely) because my Civic with sunroof and Helmet on only allows me about 1/2" clearance. And I have the seat SLAMMED on the brackets. However, in a worst case scenario or race car instance, you can use it sans sliders, which gives you another 1" of additional clearance.
go get yourself a pick-up truck
As far as I know there are different size available on the SPG, SR series(those like SR3) etc. And it's according to different countries. Say US/European dealer will have bigger dimension's seats. So maybe it's a good idea to confirm with your local dealer before u actually buy that seat.
Pls correct me if I'm wrong.
There are 2 difference sizes on SPG alone. Do anyone know if I can tell the size from the part# marked on the seats??
SPG is thinner and has shoulder grip. The SPG is lighter as well I beieve. I dunno I'm 5'11" 160 and I fit snug, but comfortable
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Night_Minx »</TD></TR><TR><TD CLASS="quote">
nice looking seat looks alittle bit wider then my zeta II and the side bolsters are way lower
they look wider also in the legs/ hips
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgiajdm »</TD></TR><TR><TD CLASS="quote">
I guess it's the fatty american version.</TD></TR></TABLE>
fatty american version?
How about you have the kiddie seat and zeta 3 is the adult seat.
I guess it's the fatty american version.</TD></TR></TABLE>fatty american version?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 »</TD></TR><TR><TD CLASS="quote">
All true. Like I said, the Bride mounting hardware is superior, adn the seat quality is equal. I just cant fit in those BRIDE JDM spec body contours since I'm 6'2" 195lbs. The Pole Position is Super Sized. it is at least 1.5" wider than the Bride pictured for sure. And like I mentioned, the lower sides allow better in-and-otu transitions in a street/daily driver.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mamaboy »</TD></TR><TR><TD CLASS="quote">i'm assuming everybody is using a rollcage with these type o' seats?</TD></TR></TABLE>
damn i was hoping we could get through an entire thread without bringing up the "darwen theory" oh well, guess not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cruzersi00 »</TD></TR><TR><TD CLASS="quote">Recaro Pole Positions may be the seat for me then.
5'10" 190lbs , all shoulders and legs = non jdm body type.</TD></TR></TABLE>
yeah probably. my zeta III is a perfect fit for me except i'm 5'10 150lbs so it might be a little tight. maybe look into the zeta III"L" if you're really intorested in a Bride. if you PM me i'll give you the name of someone that can get one for you
My zeta III
My zeta III
Guest
Posts: n/a
nope i want to die
nope i want to die
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Looose_R »</TD></TR><TR><TD CLASS="quote">bride seats arent FIA, enoug reason for me to get rid of my last set</TD></TR></TABLE>
good point. if serouse compatition is your goal then this isn't the seat for you.
night_minx & kengs: thanks for posting pix of your seat...
quick question for the both of u, ever find it hard getting in and out of it?
i sat in my friends vision seat,.... my hips barely fit in the dam thing... cant turn my body around if i wanna back up.
i'm a 34 waist aswell, btw... does the seat sit lower than stock?
