A 90 crx dx and 92-95 civic dx question
Old Apr 10, 2004 | 06:00 PM
TorganFM.'s Avatar
Default A 90 crx dx and 92-95 civic dx question
Are there any differences between these 2 setups asside from the fact that the crx dx doesn't come with mpfi while the 92-95 dx does? Would mpfi bring a crx dx up to approximately 102hp like a civic dx? Thanks in advance.
Old Apr 10, 2004 | 06:07 PM
Targa250R's Avatar
be professional
Default Re: A 90 crx dx and 92-95 civic dx question (DanW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DanW &raquo;</TD></TR><TR><TD CLASS="quote">Are there any differences between these 2 setups asside from the fact that the crx dx doesn't come with mpfi while the 92-95 dx does? Would mpfi bring a crx dx up to approximately 102hp like a civic dx? Thanks in advance.</TD></TR></TABLE>
It'd be close enough.
An MPFI conversion is the best modification you can possibly do to an '88-91 DPFI engine.
Old Apr 10, 2004 | 06:08 PM
TorganFM.'s Avatar
Default Re: A 90 crx dx and 92-95 civic dx question (Targa250R)
So other than the fuel injection the 2 motors are about the same give or take 1-2hp?
Old Apr 10, 2004 | 06:16 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DanW &raquo;</TD></TR><TR><TD CLASS="quote">So other than the fuel injection the 2 motors are about the same give or take 1-2hp?</TD></TR></TABLE>
Should be close enough.
You may also want to consider a shorter-geared transmission and a D16A6 (or better aftermarket) cam for the D15B2.
Old Apr 10, 2004 | 06:22 PM
TorganFM.'s Avatar
Thanks, man. I'm swapping in a whole D16Z6 in a few days and my friend wants the IM and **** from my 94 DX for his CRX DX so I was wondering what it would do for him.
Old Apr 10, 2004 | 06:51 PM
hatchi's Avatar
yes it will help out a little bit because he is changing 2 injector system to a 4 injector setup. By the way he might need to change his ecu as well
Old Apr 10, 2004 | 06:55 PM
TorganFM.'s Avatar
Default Re: A 90 crx dx and 92-95 civic dx question (hatchi)
Yeah he will change to a crx si ecu and will need to wire the mpfi.
jedubz
34
Aug 17, 2010 08:13 PM
civvy
Nov 3, 2005 04:53 PM
91sicrxer
11
Apr 20, 2005 07:21 AM
junglerunna
Feb 15, 2005 02:20 PM
Tyson
13
Oct 28, 2004 03:04 PM
