Need help installing axles
Old Apr 10, 2004 | 05:49 PM
ECKOTYPER's Avatar
Default i hate axels help me install
k i got the axels out last night thanks to u guys, now trying to install thought they were all the way in puttingoil in tranny and its all leaking =/ please help me what do i do to make the axels go all the way in? i was hitting the hub like crazy with the ball peen, please tell em i dont have to take the hub back apart =/
Old Apr 10, 2004 | 05:58 PM
PyR01-0347's Avatar
Default Re: i hate axels help me install (ECKOTYPER)
Did you reuse the axles seals becuase I think they might have been damaged when you took the axles out.
Old Apr 10, 2004 | 05:59 PM
Kicker773's Avatar
it's leaking because you probably tore the seal by the driver side axle. check where the leak is comiing, I can guarantee its coming from that seal if you didn't carefully put the axle back in that's whats gonna happen. The seal looks like a regular ring, rubber. Happen to me when i did a clutch install.
Old Apr 10, 2004 | 06:06 PM
RedlinedVTEC's Avatar
Jeez you guys are so quick to make the assumption that he tore a seal. My advice is to make sure that the axles are seated in all the way. You'll have to take the suspension back apart to seat them if so.
Old Apr 10, 2004 | 06:09 PM
Kicker773's Avatar
Default Re: i hate axels help me install (RedlinedVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECKOTYPER &raquo;</TD></TR><TR><TD CLASS="quote"> i was hitting the hub like crazy with the ball peen, please tell em i dont have to take the hub back apart =/</TD></TR></TABLE>
hitting it hard without aligning them properly is going to rip the seal, not an assumption but a fact.. it sucks your gonna have to take it all apart i hope you have a pressure gun.. cause taking those parts by hand is a major pain.
Old Apr 10, 2004 | 08:15 PM
Stupid's Avatar
i'll be in fresno tomorrow i can stop by and check out your ride. email: ricerocketracer209@hotmail.com
Old Apr 11, 2004 | 01:47 AM
Blazeone's Avatar
Default Re: i hate axels help me install (Stupid)
Push in till you hear a "click", do not use excessive force such as a hammer.
Old Apr 12, 2004 | 10:32 AM
ECKOTYPER's Avatar
Default Re: i hate axels help me install (BlazeONE)
i got it done just took the axel nut off and used a hammer to hammer the shaft in and it worked on each side =D
Old Apr 12, 2004 | 10:36 AM
B2FiNiTY's Avatar
So problem solved?
Old Apr 12, 2004 | 10:39 AM
Doctor CorteZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECKOTYPER &raquo;</TD></TR><TR><TD CLASS="quote">i got it done just took the axel nut off and used a hammer to hammer the shaft in and it worked on each side =D</TD></TR></TABLE>
jesus , theres a time and place for a hammer and seating axles is neither.
some spray lube would've helped them in without the brute force.
Old Apr 12, 2004 | 10:41 AM
Tweakmeister's Avatar
Default Re: i hate axels help me install (Doctor CorteZ)
I used a little coercion of the forced mass actuator (rubber mallet), works like a charm.
Old Apr 12, 2004 | 10:43 AM
Its_real&its_spectacular's Avatar
New User
Hammer bad. One hand on the inner joint to make sure it is sitting straight (shaft and the outer joint will have about 2" of lateral movement.) Use that movement like a slide hammer and just tap it in. [Happy Gilmore mode on] Taaaaap it in. Give it the old tap-tap-taperoo. [Happy Gilmore mode off]
Old Apr 12, 2004 | 01:27 PM
ECKOTYPER's Avatar
Default Re: (Its_real&its_spectacular)
hahahahaha hella funny stuff right there almost...classic... dont worry guys problem solved =D until next time i snap one =/
Old Apr 12, 2004 | 01:41 PM
92TypeR's Avatar
FSAE
Default Re: (ECKOTYPER)
Yea the only problem with the hammer method is you can screw up the end of the axle and the nut wont fit on....I learned the hard way. Rubber mallets from now on
Old Apr 12, 2004 | 05:39 PM
Mike K's Avatar
Default Re: (92TypeR)
use penetrating oil and a plastic dead blow hammer. do NOT use a regular hammer!
CivicK20
Dec 23, 2006 12:25 PM
lkailburn
26
Jan 9, 2006 08:38 PM
Doom325
Sep 23, 2005 11:24 AM
Death_to_Thieves
Aug 24, 2004 09:39 PM
MugenGTR
Jul 24, 2002 08:43 AM
