d15bvtec cuts out at 75% throttle (mini me)
Old Apr 10, 2004 | 03:11 PM
d15bcrex's Avatar
Default d15bvtec cuts out at 75% throttle (mini me)
the car is an 89 crx dx with jdm d15bvtec (stock)and a p08 ecu. it is throwing codes 9 and 21. i have checked the distributor wiring and redid it( still throws same codes). i checked the vtec wiring and redid it(same codes). i swapped ecu (same codes) and swapped distributor(same codes)the car cuts out from 75% to wot and at wot it will bogg to around 3500-4000.used boomslang jumper harness. this is gay please help me, thank you all in advance. i will give my input on any problems others have with this swap if you post.
Old Apr 10, 2004 | 05:46 PM
Redline130's Avatar
Default Re: d15bvtec cuts out at 75% throttle (d15bcrex)
Maybe there is something faulty within the wiring harness conversion. I would double check the conversion harness and make sure that everything is going to the right place.
Old Apr 10, 2004 | 07:10 PM
garlic jr's Avatar
Default Re: d15bvtec cuts out at 75% throttle (Redline130)
and what might those codes be ?
Old Apr 11, 2004 | 12:04 PM
Redline130's Avatar
Default Re: d15bvtec cuts out at 75% throttle (garlic jr)
The post says codes 9 & 21, which I believe are TDC sensor and VTEC solenoid.
Old Apr 11, 2004 | 12:45 PM
91hob20hb's Avatar
Is it bogging out or misfiring maybe? I know i had a bad plug wire once that made it seem like my motor would bog down and almost cut off when ever i pushed the pedal pasted 75% --- wot.Just an idea check plug wires
Old Apr 18, 2004 | 03:43 PM
d15bcrex's Avatar
now its throwing a 19 but still boggs could it be a ground or is it because its an auto ecu
Old May 2, 2004 | 08:01 AM
d15bcrex's Avatar
the car is fixxed now, it was a problem with the tps, it was cracked in shipping so it didnt work right
lt1guy
Aug 5, 2010 08:23 PM
DACteg
May 9, 2010 11:26 AM
silverboost
10
Aug 28, 2006 09:21 PM
teler86
15
Nov 23, 2005 03:28 AM
