Accord 97
Old Apr 10, 2004 | 01:47 PM
thory's Avatar
Default Accord 97
Hey guys I was driving back from work today and soon as I got home I saw that engine temperature was at Hot and vapor was coming out of my front hood. I popped open the hood and saw what looked like vapor coming out of a hose or something of sorts.
Anything I can do here?
Old Apr 10, 2004 | 01:50 PM
The_Todd's Avatar
Farts in the shower
Default Re: Accord 97 (thory)
Have you checked your fluid coolant level?
Old Apr 10, 2004 | 02:12 PM
thory's Avatar
Default Re: Accord 97 (VRDrvr)
Coolant is at max.
Old Apr 10, 2004 | 02:14 PM
The_Todd's Avatar
Farts in the shower
Max as in to the top? or top of the max fill line?
Whats the fluid level at cold?
I would be leaning towards thermostat.
Do your fans kick on?
Old Apr 10, 2004 | 02:28 PM
thory's Avatar
ok i just checked and when I start the car the fans in front of the radiator do not start? ? Are they supposed to be off ? There are two fans in front and neither of the start when the car starts.
Old Apr 10, 2004 | 02:33 PM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thory &raquo;</TD></TR><TR><TD CLASS="quote">ok i just checked and when I start the car the fans in front of the radiator do not start? ? Are they supposed to be off ? There are two fans in front and neither of the start when the car starts.</TD></TR></TABLE>
They are't supossed to start when you start the car. When you turn on your ac do the fans turn on? Or your car has been on for a while do the fans ever kick on? The fans turn on after your temp goes up to a certain level to keep the optimum operating tempurature.
Old Apr 10, 2004 | 02:38 PM
FatJoe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">
unless you know what youre doing, take it to a dealer, overheating engines are nooooooooo good. take care of it as quickly as you can.
Old Apr 10, 2004 | 04:41 PM
versatyle's Avatar
its most likely your thermostat, but i would replace the theromstat,coolant hoses, and get a complete flush!!...but thats if you know what you are doing! otherwise take it to the dealership!
Old Apr 10, 2004 | 07:30 PM
thory's Avatar
Hey is there some info I can read on how to replace the thermostat and coolant hoses for the 97 honda accord? I am a engineer, only not a car engineer
Old Apr 10, 2004 | 07:38 PM
.bagged's Avatar
Default Re: Accord 97 (FatJoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FatJoe &raquo;</TD></TR><TR><TD CLASS="quote">
unless you know what youre doing, take it to a dealer, overheating engines are nooooooooo good. take care of it as quickly as you can.</TD></TR></TABLE>
take it to the dealership..save the car
Old Apr 10, 2004 | 07:50 PM
gaydm.accord's Avatar
use the search button... hoses is just plug and play you just replace them but you have to flush your coolant
Old Apr 10, 2004 | 11:47 PM
iam7head's Avatar
Default Re: (gaydm.accord)
okay honda cooling 101
the cooling system you looking at is called water cool system.
it maintain a certain temperature for the engine to run properly by putting 1.1bar (or sometime more) of pressure in the sealed cooling system. The pressure raise the boiling point of the coolant. The coolant itself is some what resist to boil.
the Radiator in front is a heat exchanger, when air going pass the radiator 's aluminum/brass fins, it carry away about 100 degree of temperature from the top of the rad to the bottom(left to right if you drive a corvette, side way radiator )
the radiator hose connects the radiator to the engine block, it's flexible because the motor move on higher rpms.
The top hose (for most honda) carries hot coolant from the engine to radiator, the bottom hose carries the cooler coolant back to the engine.
think of the thermostat like a gate, when the temperature is getting hot, the gate open and allow more circling of coolant=bringing the temp down.
and here some useful idea.
the first thing you want to check is the cooling fan, check the fuse first.
if the hose is getting old and leaking, get a new sets. It should be pretty easy to spot(when hot coolant is shooting out)
a sticky thermostat could cause this problem too, especially with after-market thermostat. Use Honda's OEM stat only not even that much more compare to auto zone's stuff.
Old Apr 11, 2004 | 12:55 PM
thory's Avatar
Hey guys I found out what the problem is, it looks like one of the hoses, looks like the heater hose.. has a dime sized hole and is leaking anti-freeze. Which is what I believe is causing my engine to over heat.
Is there a map of the 97' accord engine I can look at to see extactly which hose to buy?
Old Apr 11, 2004 | 01:24 PM
DaChoZn1's Avatar
Default Re: (thory)
I'd replace both the lower and upper radiator hoses. I'm sure they're the same age. So if one has sprung a leak its just a matter of time the other will.
Old Apr 11, 2004 | 08:43 PM
thory's Avatar
replaced the heater hose, car runs like new now
rooonbo
Mar 12, 2019 02:15 PM
Rlcky
Honda Civic (2001 - 2005)
Aug 10, 2016 06:24 AM
darkbasic
Jul 17, 2010 06:38 PM
NiPpZ
Apr 21, 2010 08:41 PM
finster
Dec 19, 2008 09:19 AM
