Guages question?
Old Apr 10, 2004 | 12:04 PM
1995hatchcx's Avatar
Default Guages question?
What wire do i tie in on the distributor to wire in a tach on a b18b?
Can i run an electrical oil pressure guage or do i need to get a
mechanical or pressure guage for a b18b?
Old Apr 10, 2004 | 12:13 PM
JeffS's Avatar
Default Re: Guages question? (1995hatchcx)
It's easier to get the tach signal from the back of the cluster. Less wiring and you don't have to worry about passing through the firewall.
Splice to the blue wire on the large connector on the left side of the cluster (left side while looking at it from the front)
Mechanical or electrical is a personal preference thing. You can run either.
Modified by JeffS at 4:25 PM 4/10/2004
Old Apr 10, 2004 | 12:19 PM
Default Re: Guages question? (JeffS)
My stock cluster in my CX doesn't have a tach,
if i go elecrical witch my oil pressure guage does anyone know what
wires to use?
Old Apr 10, 2004 | 12:26 PM
JeffS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995hatchcx &raquo;</TD></TR><TR><TD CLASS="quote">My stock cluster in my CX doesn't have a tach,
That's irrelevant. The wiring is all there whether the cluster has a tach or not. Since you're lazy I just walked down and looked at the car. I've updated my first post with the correct wire information.
Old Apr 10, 2004 | 12:30 PM
scratchy's Avatar
WELL WHY DON'T YOU TRY SEARCHING
eksedan7198
Nov 1, 2013 04:15 PM
hondanube2010
Jun 30, 2010 05:10 PM
R6Boy69
Oct 24, 2003 09:05 AM
