NEED HELP WITH CHIP INSTALL ON OBD1 P72!!!!!
Old Apr 10, 2004 | 11:22 AM
SloGizzer's Avatar
Default NEED HELP WITH CHIP INSTALL ON OBD1 P72!!!!!
Well i bought a pyr chip that came with the socket, another small chip, and a jumper wire, and instructions on how to install it. A friend of mine who installed chips previously did it for me, and we followed the instructions correctly, but after we put the ecu back together and put it in the car it did absolutely nothing! Vtec stayed the same, but my redline didnt change and thats all i want from this chip. At first i thought i had a bad chip, so i had it replaced with another one, and nothing changed. the only thing that i can think of is that we soldered the socket in the wrong place!! here are some pics of the ecu and the chip installed, is there anything wrong with the installation? thanx in advance!!
Blue arrow shows the other little chip that came with it, yellow arrow shows the socket as we soldered it
Here is everything installed, red arrow is the jumper wire
here is another close up
Please let me know if there is anything wrong with the installation!! thanx
Modified by SloGizzer at 3:55 PM 4/10/2004
Old Apr 10, 2004 | 11:47 AM
JBBNJ609's Avatar
Default Re: NEED HELP WITH CHIP INSTALL ON OBD1 P72!!!!! (SloGizzer)
well on the chip it says vtec-4400 in which case VTEC did stay the same and redline 9100 well you say the red line didnt change . . . idk
just saying that vtec stock is 4400 (on a gsr and the 2ndary butterflies hit at 5700)
Old Apr 10, 2004 | 01:12 PM
00b18b's Avatar
your red arrow should be a resistor. the section "J1" right next to the red arrow should be your JUMPER wire. section where "C52" is, should have a 0.1µf ceramic disc capacitor. from the pictures i cant tell if the chip is installed the correct way with the notch pointing towards the left.
Old Apr 10, 2004 | 01:26 PM
mr.beeks's Avatar
Default Re: NEED HELP WITH CHIP INSTALL ON OBD1 P72!!!!! (00b18b)
yeap thats the only three mistakes I see in order
to work well...
place the resistor where you placed the jumper wire
the jumper wire in the J1 slot
and the missing cap
after that you should be fine..
I bought a p28 that was missing 3 items
2 caps and the jumper wire..
bought those and installed then it worked beatifully..
Old Apr 10, 2004 | 02:41 PM
SloGizzer's Avatar
Default Re: NEED HELP WITH CHIP INSTALL ON OBD1 P72!!!!! (mr.beeks)
thanx for the replies guys, i just wanna make sure that im getting what you are saying here just to be on the safe side. The jumper wire needs to be on the "j1" slot, i should have a resistor in the "r52" and a capacitor in the "c52" slot and the notch on the chip has to face to the left? So after im done with all that everything should work fine??
Old Apr 10, 2004 | 04:11 PM
00b18b's Avatar
Pics are kinda blury and i thought i saw a capacitor in "c51" but there isnt one in there so grab two capacitors and your ecu should work.
Old Apr 10, 2004 | 04:25 PM
Mr. Softee's Avatar
you have the jumper in the wrong spot. it needs to be on j1.
Old Apr 10, 2004 | 06:48 PM
eg6ajk's Avatar
Default Re: NEED HELP WITH CHIP INSTALL ON OBD1 P72!!!!! (94goldjungsr)
indeed move over the jumper wire to J1 location.
R52 should be empty. Caps are not required on C51 and C52, I personally do not use them.
Old Apr 10, 2004 | 07:41 PM
Mr. Softee's Avatar
Default Re: NEED HELP WITH CHIP INSTALL ON OBD1 P72!!!!! (eg6ajk)
i do use them. and rec them as per pgmfi.
Old Apr 10, 2004 | 09:14 PM
ozzyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk &raquo;</TD></TR><TR><TD CLASS="quote">indeed move over the jumper wire to J1 location.
R52 should be empty. Caps are not required on C51 and C52, I personally do not use them. </TD></TR></TABLE>
Yup, it will work fine without capacitors. Just move the jumper wire to "J1" and everything should be good to go.
Old May 23, 2004 | 11:24 AM
SloGizzer's Avatar
Default Re: NEED HELP WITH CHIP INSTALL ON OBD1 P72!!!!! (ozzyman)
well, i just moved the jumper wire to "j1", and plugged the chip in the socket, and then i went to start the car and got a cel!! i tried to rev it, but it wouldnt rev past 3000 rpm. i have no idea whats up with it now!
Old May 23, 2004 | 12:41 PM
Mr. Softee's Avatar
you are in limp mode.
Old May 23, 2004 | 03:27 PM
SloGizzer's Avatar
so what am i supposed to do about this? I dont know why eveything has to be such a pain in the *** when it comes to gs-rs. what do i need to do to make this thing work, im getting my cams next week, and i would like to be able to rev past stock to make some decent power with them. somebody please hellllllpp!!!
Old May 23, 2004 | 07:21 PM
Mr. Softee's Avatar
resolder all the connections and reburn the chip. one of those is your problem.
Old Jun 5, 2004 | 11:20 PM
SloGizzer's Avatar
well i bought a new chip that came with capasitors, redid everything, and as soon as i solder the jumper into the j1 slot, i go into limp mode, so i pull the jumper out, and everything goes back to stock!! i have no clue what could be wrong!! has anybody had this problem before, cuz i feel like giving up already!! this is the 3rd chip, and the problem is still the same. if anybody has any idea what is wrong please let me know!!!
Old Jun 5, 2004 | 11:35 PM
Mr. Softee's Avatar
make sure you did the install / burning correctly. its not hard, at all.
Old Feb 17, 2014 | 01:03 PM
Sandro21's Avatar
Same problem here my ecu p30 dont go more then 4000 rpms i jump j1 i set i items they send me it was 4 little squares 2white for c91andc92 and 2 brown for c50 andc49 plz help...
Old Feb 17, 2014 | 01:30 PM
B_Swapped93's Avatar
this is why you PAY someone who knows what their doing to install it it's like ppl who think an s300 is drop in...it's not I had to get my tuner to install it.
Old Feb 17, 2014 | 03:50 PM
Sandro21's Avatar
I know wat i did i installet the way its suppose
jaredvabeach
Engine Management and Tuning
Nov 28, 2009 07:28 AM
Ejalldaipesos
10
Dec 5, 2006 12:56 AM
revlimitcrx
Apr 13, 2006 02:17 PM
89Si
Nov 7, 2003 09:48 AM
93solsigsr
Apr 25, 2003 07:08 PM
