Ls Or Gsr...which should i go with to turbo with out internal work?
It's time to take my bubble to next level with a swap. Its either LS (to later go LS VTec) or a Gsr to later go turbo. I kno the Ls is the best block but how does the Gsr stand against it? Will a stock gsr block under turbo handle it as good as a Ls?
thanks ahead of time.
how about you stop trying to raise your post count and just post search all in one post
Just remember a gsr motor will make more power than an ls motor on the same amount of boost.
gonna hear a lot of "well my b18b turbo makes more horsepower and torque than your b18c1 turbo"
we dont want to hear that crap. we're talking about stock motor with turbo, and at the same boost. not i have this and that in my motor, with this turbo, and it made so and so power with this much boost. as MShue already mentioned, a b18c1 turbo will make more power than a b18b with the same specified turbo and same boost.
I though that LS motor is the strongest out of all b series, so I though you can run more boost on stock internals
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">I though that LS motor is the strongest out of all b series, so I though you can run more boost on stock internals</TD></TR></TABLE>
no LS motor has slightly more torque because of about 30 cc's of displacement and a longer stroke...
the GSR is built better . stock girdle .. oil sprayers .. much better
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sprfreek »</TD></TR><TR><TD CLASS="quote">
the GSR is built better . stock girdle .. oil sprayers .. much better</TD></TR></TABLE> It also has a better flowing head then the Ls.
[QUOTE=SOHC_MShue]how about you stop trying to raise your post count and just post search all in one post
[QUOTE]
It was a joke, do you think he really cares about # of posts?
A GSR has beefy rods, compared to a LS. The only issue with boosting a GSR is the compression. A US spec OBDII has somting like 10.3 ratio (or 10.2?), so you are already a little high. Which means u can't put that many lbs of boost to it, but if you repalace the pistons then u solve the issue. Even if not, you are still looking a high hp GSR even if ur only at like 8-9lbs boost. Another problem si the gear ratio of teh GSR is really better for NA applications, the LS tranny would be more ideal if u go this route. Hince the longer gears.
The LS is great because it is cheap, you can replace the rods and pistons alone and have almost a full bar of boost and be kicking a lot of *** on the highway. It is a lot cheaper engine that can have = potential of a boosted GSR for = ammount of money. That being LS engine + new rods + new pistons+ labor for LS, compared to GSR engine+turbo +labor.
hope that makes sense.
[QUOTE]
Well you thought wrong.
The LS rods are thinner, and thus weaker than GSR rods.
To answer the question though, I would prefer to run a stock LS engine than a stock GSR. First and foremost because the LS is cheaper. Other reasons include lower compression, and not having to deal with the cam overlap of vtec.
Have it tuned right and you won't have a problem running a reasonable amount of boost on either.
[QUOTE=greebler]
[QUOTE]
i would think that the gsr tranny would still be good, as long as he isn't going crazy with boost making like 500whp, somebody correct me on this though.
[QUOTE]
[QUOTE=star&buc
i would think that the gsr tranny would still be good, as long as he isn't going crazy with boost making like 500whp, somebody correct me on this though.[/QUOTE]
First of all... using a LS or GSR engine doesn't necessarily imply that you will be using the matching transmission. There has been endless debate about this - and I feel it's partially dependent upon your turbo setup, specifically how fast your turbo spools.
The idea that a GSR tranny is bad for boost is false though. In some cases it would definitely result in better performance than the LS.
boosted LS is where its at, GSR might make more hp at same boost level, but how much more tq will the LS have. i'm currently running stock b18b @12psi making 323whp 270wtq. most GSR don't run 12psi, and they make like 300+hp 220tq. i'd say if you gonna stick with stock motor, the LS is tough to beat - provides a good hp -tq ratio and makes great numbers. i've used both the GSR and LS tranny on my turbo setup - the GSR tranny is 100x better!!
edit: if you're gonna build it .. definately go GSR, but only if you're gonna build it
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18bEK »</TD></TR><TR><TD CLASS="quote">boosted LS is where its at, GSR might make more hp at same boost level, but how much more tq will the LS have. i'm currently running stock b18b @12psi making 323whp 270wtq. most GSR don't run 12psi, and they make like 300+hp 220tq. i'd say if you gonna stick with stock motor, the LS is tough to beat - provides a good hp -tq ratio and makes great numbers. i've used both the GSR and LS tranny on my turbo setup - the GSR tranny is 100x better!!
edit: if you're gonna build it .. definately go GSR, but only if you're gonna build it</TD></TR></TABLE>
a 300-325 b18c1 should make more than 220wtq? im making almost that on a b16a...
The bottom line is the LS motor cost less so you can spend more money building the block and replacing the internals
LS Turbo
The only way I'd go with the GSR is if I wasn't putting the turbo on right away, just because I couldn't stand driving around with a stock LS motor
Vtec
LS Turbo
Vtec
hey abk i can not reply to the thread I left about the p28 if you have it I would like to buy it. It would be better than what is in there right now just let me know how much. heres my address 1211 henning ave evansville IN 47714 my phone is 821-401-2379. Just let me know what you want for it. Thankx Jason insaneimportz.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 »</TD></TR><TR><TD CLASS="quote">
a 300-325 b18c1 should make more than 220wtq? im making almost that on a b16a...</TD></TR></TABLE>
maybe a little more, but not much. they are dogs when it comes to tq
