restrictor plate??
Old Apr 10, 2004 | 09:17 AM
JohnnyLux's Avatar
Default restrictor plate??
i opened up my dp-fi top cover just to look inside and i found an L-shaped peice of metal where the intake connects to the air chamber. if i take it out will it hurt my engine, do nothing, or make it run better (fuel economy is key).
Old Apr 10, 2004 | 09:37 AM
T S R Performance's Avatar
Default Re: restrictor plate?? (civic90)
i did it to mine when i had DPFI and it seemed to open up a little more air and make a little bit more noise. hardly noticeable though. try it out i guess. its only 2 screws.
Old Apr 10, 2004 | 10:28 AM
Mr_CRX's Avatar
Default Re: restrictor plate?? (CivicHatchSOHC)
i've heard this is what makes the biggest difference between the d15b1 and the d15b2 cause they're rated like 20hp apart or something? i forget the exact specs..
i'm sure if you remove it, you'll get a little better response from your engine, and I doubt that it'll hurt your fuel economy much. my d15b2 that burned like a quart of oil every week and a half still got 30mpg.
Old Apr 10, 2004 | 01:07 PM
JohnnyLux's Avatar
Default Re: restrictor plate?? (Mr_CRX)
well i took it out does seem a bit more responsive guess ill just toss that in my junk pile to thanks guys
361 accord
Oct 11, 2010 11:13 AM
Smarties
Oct 19, 2008 06:15 AM
98dxhatch
13
Aug 6, 2003 10:48 AM
DJOwenXC
Jan 18, 2002 02:12 PM
Ohlias
Oct 20, 2001 04:36 PM
