how much tranny fluid does a b16 tranny hold?
Just dumped my tranny fluid for synchromesh, it took 2 and 3/4 bottles till it started floeing out of filler hole, my only question is does it make a difference if the car was jacked up in the front when filling, does this effect amount of fluid you can pour in?
The manual calls for 2.3 liters - jacking the front up would have tilted it back a bit, as long as you have at least 2 and a little in there, its fine.
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16EG »</TD></TR><TR><TD CLASS="quote">Just dumped my tranny fluid for synchromesh, it took 2 and 3/4 bottles till it started floeing out of filler hole, my only question is does it make a difference if the car was jacked up in the front when filling, does this effect amount of fluid you can pour in?</TD></TR></TABLE> This does maker a minor difference in the amount of fluid that stays in the tranny. But as MKC said the difference is so minimal that it is irrevelant. Happy Tuning!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00MRSi »</TD></TR><TR><TD CLASS="quote">You should be fine. Why not stick with Honda MTF? </TD></TR></TABLE>
Because gm syncromesh fm is supposively better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">While were on the subject, how much goes into a GSR tranny? </TD></TR></TABLE>
Same 2.3 qts.
Same 2.3 qts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">
Same 2.3 qts.</TD></TR></TABLE>
All B-series take 2.3qts.
hey so do i fill the tranny with fluid till it flows out of the fill hole? reason i ask is because i was swaping my tranny to another motor and fluid came out the axle port and i dont know how much spilled
if fluid came out of the axle port, it sounds like a bad axle seal. working in independent import repair shop, we always fill a trans until it starts to flow out of the filler plug and call it good.
Use Honda MTF, 10W-30 engine oil, or a compatible lightweight synchromesh transmission lubricant such as Amsoil Synthetic Synchromesh MTF 5W-30 or GM Synchromesh. Do not use standard gear oil containing sulfur or boron (75W-80, 80W-90, etc.) because you will cause damage to the transmission.
He was swapping the transmission. The axle was out; there's nothing to seal against.
mikeintegra93
Jan 9, 2009 04:12 PM
Hondapreludeg
May 16, 2008 01:21 PM
