how much tranny fluid does a b16 tranny hold?
Just dumped my tranny fluid for synchromesh, it took 2 and 3/4 bottles till it started floeing out of filler hole, my only question is does it make a difference if the car was jacked up in the front when filling, does this effect amount of fluid you can pour in?
Re: how much tranny fluid does a b16 tranny hold? (B16EG)
The manual calls for 2.3 liters - jacking the front up would have tilted it back a bit, as long as you have at least 2 and a little in there, its fine.
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16EG »</TD></TR><TR><TD CLASS="quote">Just dumped my tranny fluid for synchromesh, it took 2 and 3/4 bottles till it started floeing out of filler hole, my only question is does it make a difference if the car was jacked up in the front when filling, does this effect amount of fluid you can pour in?</TD></TR></TABLE> This does maker a minor difference in the amount of fluid that stays in the tranny. But as MKC said the difference is so minimal that it is irrevelant. Happy Tuning!!!
Re: how much tranny fluid does a b16 tranny hold? (00MRSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00MRSi »</TD></TR><TR><TD CLASS="quote">You should be fine. Why not stick with Honda MTF? </TD></TR></TABLE>
Because gm syncromesh fm is supposively better.
Former Moderator
Let's not turn this into yet another damned GM Synchromesh fluid topic thanks.
2.3 is the correct answer though...
Former Moderator
Re: how much tranny fluid does a b16 tranny hold? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">While were on the subject, how much goes into a GSR tranny? </TD></TR></TABLE>
Same 2.3 qts.
Same 2.3 qts.
Re: how much tranny fluid does a b16 tranny hold? (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">
Same 2.3 qts.</TD></TR></TABLE>
All B-series take 2.3qts.
hey so do i fill the tranny with fluid till it flows out of the fill hole? reason i ask is because i was swaping my tranny to another motor and fluid came out the axle port and i dont know how much spilled
if fluid came out of the axle port, it sounds like a bad axle seal. working in independent import repair shop, we always fill a trans until it starts to flow out of the filler plug and call it good.
be professional
Use Honda MTF, 10W-30 engine oil, or a compatible lightweight synchromesh transmission lubricant such as Amsoil Synthetic Synchromesh MTF 5W-30 or GM Synchromesh. Do not use standard gear oil containing sulfur or boron (75W-80, 80W-90, etc.) because you will cause damage to the transmission.
He was swapping the transmission. The axle was out; there's nothing to seal against.
mikeintegra93
01-09-2009 04:12 PM
Hondapreludeg
05-16-2008 01:21 PM
