HELP! broke my obd2->obd1 harness
Old Apr 9, 2004 | 07:20 PM
milano2kdc2's Avatar
Default HELP! broke my obd2->obd1 harness
I was crimping wires and what not on the harness putting in the fields vtec controller, then i noticed that one of the wires were loose and now its like this
Is there anyway i can repair this? cause i dont want to buy another one.
thanks
btw its a jdmshit harness
Old Apr 9, 2004 | 07:49 PM
Danger's Avatar
Default Re: HELP! broke my obd2->obd1 harness (Milano2kDC2)
did the pin come out or did it brake off ? if it broke off , use a little "pic" to push out the broken pin . then if you have access to other pins jus cut and solder on a new one . hope that helped .
Old Apr 10, 2004 | 12:40 AM
Default Re: HELP! broke my obd2->obd1 harness (JonnyDanger)
where do i get new pins?
Old Apr 10, 2004 | 09:59 AM
up
Old Apr 10, 2004 | 04:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Milano2kDC2 &raquo;</TD></TR><TR><TD CLASS="quote">where do i get new pins?</TD></TR></TABLE>
Old Apr 10, 2004 | 05:04 PM
Boost2NA's Avatar
I feel your pain man. Look up username kenji and send him a e-mail (id send a e-mail rather than a IM , not to sure he still posts here ). He will be able to hook you up with some pins.
Old Apr 11, 2004 | 04:27 AM
kenji's Avatar
Default Re: HELP! broke my obd2->obd1 harness (Boost2NA)
I should be able to come up with some pins for you.
Now do you guys see why it is important to put epoxy over the connections? It prevents this from happening (pins breaking from fatigue of the metal).
I have fixed quite a few of the Skunk2 and other harnesses out there over the years.
I put epoxy on all of my harnesses that I make. Do any of the ~$75 harness guys do this?
You get what you pay for...
-kenji
Old Apr 11, 2004 | 09:28 AM
Blown90hatcH's Avatar
Default Re: HELP! broke my obd2->obd1 harness (kenji)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kenji &raquo;</TD></TR><TR><TD CLASS="quote">Now do you guys see why it is important to put epoxy over the connections? It prevents this from happening (pins breaking from fatigue of the metal).
I have a few thousand pins laying around if you need some too.
Jason
http://www.JKOBDConversionHarness.com
CKnight90
Aug 25, 2013 03:36 AM
dougshatch
Apr 24, 2007 01:13 PM
CHK4TIX
Feb 4, 2007 07:54 AM
tallblondkid
Jun 24, 2004 04:15 PM
Longevitee
Mar 7, 2004 10:11 AM
