6x9 Speaker Installation HELP!!
I got some pioneer 6x9s for my 96 civic dx but im having a bit of a problem because i have no idea how to install them cuz the back panel isnt coming off as easily as i thought so if any body has info let me know
Modified by Spiketrunks at 12:39 AM 4/10/2004
ok. this is wut u have to do.
first ur gonna have to take off the bottom part of the back seats. there is one bolt that is 10mm in the back of the seat.
after removing this. your gonna have to take off the side panels. both passenger and driver side panels.
before the panels are able to come off, u have to fold down the back seats and take out the 4 bolts that are hold then in place. after taking these bolts off, there will be another bolt that has to come off just underneath the bracket that holds the seats together. this in turn will allow the side panels to come off. one the side panels come off.
your gonna have to take the three bolts off that are connected to the top of the rear deck. also make sure that you disconnect your third brake light if u have one.
once all this is removed the rear dashboard should just come off with a few pulls. there is about 4 snap-on clips that you have to release. and vhalla...the rear speakers are visible and ur able to swap them out with the ones that you have. yes this is a pain. i just finished my install of 6x9's. i put a set of Focal Access 690CA speakers in there. they sound amazing. let alone i also put another amp in there for the rear speakers. this whole project of running 2 new RCA cables and redoing the wiring, wiring up the distributor block, the cap, and two amps, and removal of the rear dashboard and completing the install took me 4 packs of cigarettes, 2 12 pack of beer and about 11 hours. i think its worth the trouble. but hondas are really gay when you have to do the rear speakers. hope this helps you. sorry i didnt take any pics. but if you need me hit me up on AIM at deathklone....or email me at hamidnj@comcast.net with any questions.
FSUseminoleEM1
Dec 17, 2009 10:21 AM
