car rasied it self by itself??
Old Apr 9, 2004 | 12:38 PM
patastinky's Avatar
Default car rasied it self by itself??
riding on SprintEXtreme springs 3.25 drop Bilstien shox up front stock in the back..
and for the 2nd time my front driver side wheel gap is 3 finger? wtf.. normally it's 1 finger or a 1/2 finger... but no it's 3 finger what would cause this!?
last time it happen w/ other bilstein shox after a week or so of driving, so i put on a blown oem one till i got the bils replaced.. but no it happened again!!
a year ago i hit curb doing 45mph coming on to an on ramp on the high way and bent the **** out of my LCA but i replaced, could this be the probleM? maybe i over looked a bent suspension part thatis' ******* up my shox!?
thing is if i ride w/ the oem blown shock i never get this problem only when i am ridin on the bils..
Old Apr 9, 2004 | 07:05 PM
Riceburner247's Avatar
Default Re: car rasied it self by itself?? (patastinky)
Just lowered Blondeaccord's car with Sprint Extremes and Tokico Blue's.
She has even gap all the way around and it looks damn good.
If you've had damage to that corner of the car before, I would give everything a thorough inspection. That most definately is affecting your setup. If you do find a defect with the Bilsteins, you should be able to return them.
Old Apr 9, 2004 | 07:10 PM
patastinky's Avatar
Default Re: car rasied it self by itself?? (riceburner247)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner247 &raquo;</TD></TR><TR><TD CLASS="quote">Just lowered Blondeaccord's car with Sprint Extremes and Tokico Blue's.
If you've had damage to that corner of the car before, I would give everything a thorough inspection. That most definately is affecting your setup. If you do find a defect with the Bilsteins, you should be able to return them.</TD></TR></TABLE>
how much of a gap does he/she have up front and in the rear?
Old Apr 12, 2004 | 04:46 AM
FastAssH22Accord's Avatar
How do the sprint extreme's ride?
Jason
Old Apr 13, 2004 | 07:45 PM
patastinky's Avatar
Default Re: car rasied it self by itself?? (FastAssH22Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastAssH22Accord &raquo;</TD></TR><TR><TD CLASS="quote">How do the sprint extreme's ride?
Jason</TD></TR></TABLE>
love them .. not bouncy at all they are pure sex
Old Apr 13, 2004 | 08:22 PM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patastinky &raquo;</TD></TR><TR><TD CLASS="quote">
how much of a gap does he/she have up front and in the rear?</TD></TR></TABLE>
Check the accord picture thread its in there
Old Apr 13, 2004 | 08:30 PM
-RedneckDave-'s Avatar
Working
Sounds like the spring is rotating adn getting out of the seat which might raise it up, but i don't know if that is the case here. Just a suggestion.
Old Apr 13, 2004 | 08:52 PM
FatJoe's Avatar
Default Re: car rasied it self by itself?? (01accordv6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01accordv6 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like the spring is rotating adn getting out of the seat which might raise it up, but i don't know if that is the case here. Just a suggestion.</TD></TR></TABLE>
it sounds a lil extreme to be that sort of problem... that would only cause it to lift half an inch at most... if even close to that. maybe the struts have some sort of problem where they get stuck when compressing and just dont compress all the way that it should with the weight of the vehicle on it... maybe you just ride around with fat bitches too often and when they get outta ur car it raises itself up haha nah just kidding... who knows man, maybe you should find a different strut to gfo with....see what happens
Old Apr 13, 2004 | 08:55 PM
Working
Default Re: car rasied it self by itself?? (FatJoe)
I only really said that because he said he had replaced the front struts and i assumed he installed them correctly but maybe if they were used and they had been in a wreck and had a bent shaft then they might stick that bad. I don't know i am rambling.
Old Apr 13, 2004 | 08:58 PM
FatJoe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01accordv6 &raquo;</TD></TR><TR><TD CLASS="quote">I only really said that because he said he had replaced the front struts and i assumed he installed them correctly but maybe if they were used and they had been in a wreck and had a bent shaft then they might stick that bad. I don't know i am rambling.</TD></TR></TABLE>
suspension problems are always the best because there are so many damn components that could be causing the problem. its like a freaking circus under there. the strut sticking could be it. its a logical explanation really. who knows tho. if i were you, i would take everything apart and look everything over and double check you have everything in order and everything is in good condition. only thing i can think of. good luck
Old Apr 13, 2004 | 11:40 PM
patastinky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FatJoe &raquo;</TD></TR><TR><TD CLASS="quote">
suspension problems are always the best because there are so many damn components that could be causing the problem. its like a freaking circus under there. the strut sticking could be it. its a logical explanation really. who knows tho. if i were you, i would take everything apart and look everything over and double check you have everything in order and everything is in good condition. only thing i can think of. good luck </TD></TR></TABLE>
the mind boggles... i am taking it to a suspension tech in a couple of hours to tell me if i have any bent suspension parts.. because i just dont get what's going on .. i replaced the front driver side bilstien shock 2wice and same thing happened.. If i take the shock out though and try to compress it seems to go down all the way and it would normally.. i dont think it's the shock though i think there is something that is stopping my suspension from moving and higher ( by that i mean UCA going higher up into the wheel, making the car lower to the ground ) ... what if i bet a tierod or something or shifted the center crossmember a lil bit? i would assume that even the smallest bit would mess up my whole shizle blah!! grr.. soo frustrating..
i will keep u guys posted tomorrow see what this guy says'
funny thing is i put a blown oem shock and and it sits normal again, dont know wtf is up w/ the bils going out on me ONLY on the driver side after a couple of weeks.. after it raises itself, there is no suspension travel what so ever driver side is hard as a brick
Old Apr 14, 2004 | 12:02 AM
kittedaccord's Avatar
patastinky, did u ever go to EBAUMSWORLD? that pix is hilarious, im sorry, this is soo of the sub. and oh yeah i would assume sumthing is bent in ur set up.good luck.relax ull fig it out.
Old Apr 14, 2004 | 02:35 PM
patastinky's Avatar
Default Re: car rasied it self by itself?? (kittedaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kittedaccord &raquo;</TD></TR><TR><TD CLASS="quote">patastinky, did u ever go to EBAUMSWORLD? that pix is hilarious, im sorry, this is soo of the sub. and oh yeah i would assume sumthing is bent in ur set up.good luck.relax ull fig it out.</TD></TR></TABLE>
spanxxx... anyways took ot the place and they said that it's only off 1 degree on my driver side, but that everything looks good.. i asked them if they check the knukle and if it looks best etc.. or the center crossmember.. but they said they really only go bay camber and how bad it is... so i am gonna try to replace everything from UCA down to LCA knuckle and all.. and if that dont help then imma have to get parts car can swap out Center Crossmembers.. woo wooo what fun
thanx everyone for there helps and opinion's on what the problem might be
peacepeace
LuiS
Old Apr 14, 2004 | 05:59 PM
FatJoe's Avatar
good luck man.
Old Apr 14, 2004 | 06:56 PM
patastinky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FatJoe &raquo;</TD></TR><TR><TD CLASS="quote">good luck man. </TD></TR></TABLE>
thanx co0kcrackMAN!!!
Loyalty iZzle..
zccrx
Apr 29, 2008 03:27 PM
M@
Nov 18, 2007 01:41 PM
blackrag
15
Feb 20, 2007 09:16 AM
B18CR-X
Suspension & Brakes
Feb 23, 2005 02:27 PM
Mugen Hamster
Oct 17, 2002 01:21 PM
