Wheel Hop, what to do???
Old Oct 26, 2001 | 10:10 PM
HondaCutter's Avatar
Default Wheel Hop, what to do???
Since I got my turbo I've been having wheel hop issues. I've already ruined my CD player because of it, is there anything I can do to keep my tires on the ground?
Thanks
Old Oct 26, 2001 | 10:30 PM
PureTeg420's Avatar
Default Re: Wheel Hop, what to do??? (HondaCutter)
Z10 radius arms? Not too expensive, and doesn't have any drawbacks that I know of.
Old Oct 26, 2001 | 10:36 PM
WykidEH's Avatar
Default Re: Wheel Hop, what to do??? (PureTeg420)
You said it . . . . .and there's one more thing you can do also. . . . . get the Hasports solid rear engine mount, not the inserts. . . . www.hasports.com
Hope this helps.
Old Oct 27, 2001 | 12:21 AM
DamonBoost's Avatar
New User
Default Re: Wheel Hop, what to do??? (WykidEG6)
Where can u get those radius arms? Does anyone have a link and a price?? thanks
Old Oct 27, 2001 | 12:54 AM
JFK78's Avatar
Default Re: Wheel Hop, what to do??? (Damon501)
I've been having a lot of wheelhop in 1st & 2nd gears w/turbo also, even with the polyurethane motor mount inserts.
I was wondering if getting new shocks would eliminate most of it. I have sprint 2.25" springs on the stock shocks with 60,000 miles on them. The car still seems to handle fine, but I was thinking that getting some KYB AGX adjustables would pretty much solve the problem.
Does anyone have any input on this?? Or would the Z10 radius arms be the answer?? I only have enough $$ right now to get one or the other, and I'm stuck as to which would be better. Any help would be greatly appreciated.
Old Oct 27, 2001 | 03:44 AM
GruvyTune's Avatar
New User
Default Re: Wheel Hop, what to do??? (JFK78)
will the Z10 radius arms fit on your car with turbo on? They are supposed to go where the tow bars are on the front. Those were taken off when my turbo went in to fit the intercooler pipes on the car.
Old Oct 27, 2001 | 04:44 AM
slywfbpsi's Avatar
I had the kyb agx's in the front of my car with engine mount inserts, they didn't get rid of my wheel hop, when I switched to tokico illumas, they took care of it, no wheel hop at all, with weapon-r circuit pro coilovers.
Old Oct 27, 2001 | 07:22 AM
WykidEH's Avatar
Default Re: Wheel Hop, what to do??? (slywfbpsi)
Here's the link to Z10. . . . http://www.z10eng.com/index2.htm
YOu can run the bar w/Turbo, It won't be in the way.
Old Oct 27, 2001 | 09:47 AM
JFK78's Avatar
So you say the illumina's stopped it, huh? I did a search and everybody seems to say that the AGX's are just as good as the illumina's, but cheaper. Even on full stiff, they still had wheelhop??
The Z10 site says they completely eliminate wheelhop, which is exactly what I want. Is anyone using these that can vouch for the fact that they really work??
Old Oct 27, 2001 | 10:24 AM
BoostinDC2's Avatar
also competition engineering makes a traction system also
Old Oct 27, 2001 | 11:07 AM
DamonBoost's Avatar
New User
Default Re: Wheel Hop, what to do??? (BoostinDC2)
anyone have a link or price on these?
Old Oct 27, 2001 | 11:21 AM
jamal-188's Avatar
Here's a link to the integra ones; http://www.modacar.com/acura/framese...bars_acura.htm
They sell for $319, not sure how good they work?
Old Oct 27, 2001 | 12:41 PM
BoostinDC2's Avatar
Default Re: Wheel Hop, what to do??? (jamal-188)
its weird how the competition engineering ones tell u to remove them for the street.
Old Oct 27, 2001 | 05:22 PM
slywfbpsi's Avatar
the agx's were nowhere as good as my illuminas, they could not handle my 450 srping rate for nothing, even at full hard. going over a speed bump, at like 2 miles an hour, just creeping over it, and the shock would bottom out when I made it over the hump. at the track I could not get rid of wheelhop woth the agx's, 1-4 no difference. raise or lower the car no difference. I finally just raised the car all the way up and rode around on 4, becuase that would absorb most of the street's imperfections. When I switched to the illumas, the difference is defintely realizable, no problem with speed bump, imperfection is the road the I used to have to avoid, i can go over them (I notice that they are there, but they don't have as any harshness as they had before). setting 2 on my illuminas provided the same amount of damping as setting 4 on the agx's. Plus when I went ahead and lowered the car another inch, the ride, still got better, my cornering speed are ungodly now. Showing off with a friend at the light, I launched at 4500 rpms, and the car just peeled, no wheelhop as before, no "bang, bang, bang." Hell, I ride around now at 3 front, and 1 rear, now and I get better ride, damping, and stablitly, than, the 4 front, and 3 rear, I had to ride with the agx's.
Old Oct 27, 2001 | 06:17 PM
Kamin's Avatar
yea i have pretty bad wheel hop NOW in my car
im afraid of what it will be like after i get the engine swapped and add a turbo
i should invest in one of those
and a better suspension setup too
[Modified by KAMiN, 3:17 AM 10/28/2001]
Old Oct 27, 2001 | 07:05 PM
Hispeed's Avatar
Default Re: Wheel Hop, what to do??? (KAMiN)
I am using the comp engineering ones on my turbo street car. I absolutely love them. But be warned... you will need to do some cutting on the bracket (brace) that connects to the side torque mount (driver side). It really wasn't a big deal but It definately was not a bolt on affair with the turbo installed due to the piping. I have no problem running them on the street. And yes they due TOTALLY eliminate wheel hop. They improved my 60' by .15 secs just by bolting them on.
Nooch
20
Jun 30, 2010 05:05 AM
WishILivedInJapan
Nov 24, 2004 10:22 PM
HRDCORD
Dec 9, 2003 07:23 AM
SIK IN DA HED
Jun 6, 2002 01:03 AM
BoM
Oct 15, 2001 02:38 PM
