cam gears for sohc universal?
Old Apr 9, 2004 | 11:19 AM
xXx Justin xXx's Avatar
Default cam gears for sohc universal?
wondering if i need a gear made specificly for my d16y7. or if a z6 or y8 head would work. thanks
same question for adjustable FPR's. thanks everybody
Old Apr 9, 2004 | 11:21 AM
sohcvtec1995's Avatar
Default Re: cam gears for sohc universal? (SOHC b00st)
Most FPR's are the same. It really depends on the name brand. And as for cam gears as long as it is d series to d series they will fit. (excluding the d16a1)
Old Apr 9, 2004 | 11:38 AM
pornstarSR's Avatar
fuel pressure reg you can use either. but if you have a y8 you may need to get the specific one because the fuel return line needs to curve 90 degrees to get past the throttle rotor...i had this problem on mine when i swapped a y8 IM on my y7
cam gear...its engine specific...but goes in year ranges
aem cam gear
Honda Civic 1996-00 D16 SOHC 23-604
Honda Civic 1988-95 D15/D16 SOHC 23-600
aem fuel pressure reg
Honda Civic 96-00 Civic EX 25-304
Honda Civic 1995 All 25-300
the model numbers are different so there must be something alittle different between the two
Old Apr 9, 2004 | 11:56 AM
Default Re: cam gears for sohc universal? (pornstarSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pornstarSR &raquo;</TD></TR><TR><TD CLASS="quote">fuel pressure reg you can use either. but if you have a y8 you may need to get the specific one because the fuel return line needs to curve 90 degrees to get past the throttle rotor...i had this problem on mine when i swapped a y8 IM on my y7
aem cam gear
thats right the 96 and up timing belt is different or something like that.
Old Apr 9, 2004 | 12:24 PM
axhandler's Avatar
Default Re: cam gears for sohc universal? (sohcvtec1995)
Another thing the think about is that the stock cam gear has a tooth on it that fits into a groove on the camshaft. Most aftermarket cam gears do not have this tooth. You have to by the "key" from Honda. All the B series motors use them so they are not hard to find.
If you search you can probably even find the part number.
Also, a cam gear on an SOHC motor isn't giong to do much of anything unless paired with a cam.
Old Apr 9, 2004 | 01:01 PM
Default Re: cam gears for sohc universal? (axhandler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axhandler &raquo;</TD></TR><TR><TD CLASS="quote">Another thing the think about is that the stock cam gear has a tooth on it that fits into a groove on the camshaft. Most aftermarket cam gears do not have this tooth. You have to by the "key" from Honda. All the B series motors use them so they are not hard to find.
Also, a cam gear on an SOHC motor isn't giong to do much of anything unless paired with a cam.</TD></TR></TABLE>
or you can get the woodruf key at your local auto parts store.
Old Apr 9, 2004 | 01:10 PM
well. it is mostly just to give me extra timing room when i tune my hatch on the afc hack. i hope i dont need it. but my dizzy is 80% of the way advanced and the timing is set at like -1*.
when messing with the timing when tunning the hack. they remove timing (retard) when tunning dont they? in this case. i wont need the gear. but im thinking the PFR might come in handy helping get the idle smooth and all.
Old Apr 10, 2004 | 08:54 AM
axhandler's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">
or you can get the woodruf key at your local auto parts store.</TD></TR></TABLE>
I looked at every local store within 30 minutes of my house and none of them had one that was the right size. Jacksonville sucks...
I guess if I had a bench grinder I could have made one fit...
Old Apr 10, 2004 | 08:57 AM
axhandler's Avatar
In that case then yeah I guess the gear could give your tuner some wiggle room when tuning.
Can't really hurt anything...
dudenhymer
Sep 29, 2010 07:10 AM
trompeta performance
Jan 2, 2007 09:16 PM
ceLtic
Jun 29, 2004 02:59 PM
Big P
Jul 11, 2003 01:59 PM
