VAFC for a sohc vtec
Old Oct 26, 2001 | 09:53 PM
willyboyK20's Avatar
Default VAFC for a sohc vtec
I am planing to put bolt ons and a cam and maybe a little head work on my ex civic and i want to make sure the air/fuel ratio is good when all to the mods come together. I was wondering if the apexi VAFC is a good choice rather than using just a adj. fuel pressure regulator
Old Oct 26, 2001 | 10:40 PM
true jdm's Avatar
New User
Default Re: VAFC for a sohc vtec (willyboyD16)
do you need LSD tranny for your sohc motor...
adam
jdmstriver@yahoo.com
Old Oct 27, 2001 | 03:47 AM
maxim's Avatar
V-AFC is only good for fine tuning your fuel mixture after you have adjusted the desired fuel pressure with the fpr. If you are happy with the stock pressure then go for it, but you won't be getting the maximum benifit of the V-AFC. My suggestion is to have both, but it really kind of depends on what your plans are for the engine.
Old Oct 27, 2001 | 10:38 AM
DragII's Avatar
25 Year Member
Default Re: VAFC for a sohc vtec (maxim_force)
VAFC is a good little toy....I miss mine already.
you will need to spend some time on the dyno if you want best results though.
dand39
Jan 29, 2005 08:55 AM
BLK99VTECR
Oct 23, 2003 12:07 PM
bartek_b
May 11, 2003 10:03 AM
Mike95lude
Oct 10, 2001 10:53 AM
