Volts droping after 4 grand
There is something wrong with my car, it idels fine about 13.6 v's, but when i am driving and i mash the gas after 4 grand my car acts like the battery is runing out, it goes to 10 or 11.1 v's and gets really slow when i am on it, but if i gas it really slow it doesn't do it, it's very strange?
anyone know whats sup
also when i hit the gas hard after 4 grand my greddy turbo timmer starts to count down like i shut off the car, it turns on and off, it has never done this beofe? I never touch the greddy turbo timmer
@ night when the volts drop all my lighting gets really dim inside and outside and i lose alot of power wtf
Think the dizzy is going bad?
Coil?
Plugs?
anyone know?
Coil?
Plugs?
anyone know?
How do the brushes look on the alternator? It sounds like it may have had heavy duty cycles, and is wearing out. I'd check the alternator first. Take it off the car and bring it to ricer zone or someplace like that where they test it for free.
If the alternator spins faster it only make sence it make more power but could it be the pulley the is slipping or I'm just stupid and should just shut up.
im going to reset the ecu and see what happens, it starts fine so i know it's not the starter, i have no iac, so it idel @ 1k and it is at 13 volts, and when i hit the gas after 4k it goes to like 10 volts
i took out my battery to see if the alt will charge and after i dised the battery the car just dies
any have a how to on take off and on the alt for a D16?
Links?
Links?
Ok, one more time.
It is your alternator!
it should be three or four bolts that attach it to the block and a couple of quick release wire clips... nothing special, just go take a look at it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge »</TD></TR><TR><TD CLASS="quote">i took out my battery to see if the alt will charge and after i dised the battery the car just dies
Links?</TD></TR></TABLE>
You'll have to pull you driver's side axle out to get the ALT. out...
ya, alternator is toasted.
time to get rid of the 4 15's in your trunk yo!
seriously though, if you've got a big amp or whatnot it might be time to think about downsizing your stereo if you have one. honda alternators dont like big stereo systems.
BTW you don't have to take any axles out to take off your alternator. It's two bolts, one on top and one the bottom. The only problem you may run into is the bottom bolt sometimes its stuck and you have to fight with it.
Edit: Dont forget the wire and the clip...lol
Keith
Apr 5, 2005 09:43 PM
