what car does this fit..?
Old Apr 9, 2004 | 05:33 AM
dip-set's Avatar
Default what car does this fit..?
i purchased it used for my 96 ls but it wont clear the brake fluid reservior,if the reservior was closer to the firewall it would bolt right up..ive been told its for a 92-95civic,gen vr6 vw,and itr...but no one knows for sure...can someone help me determine what car its for so i can resell it...thanks..
here it is..
if anyone is interested in it pm me...i took off the yellow sticker and its freshly painted black,with a new sticker it will look like its right ot the box..
Modified by b18b-se at 10:50 AM 4/9/2004
Old Apr 9, 2004 | 06:34 AM
VTEC 101
Guest
Posts: n/a
Default Re: what car does this fit..? (b18b-se)
I have no clue.
Old Apr 9, 2004 | 06:37 AM
95integraLS's Avatar
are there any kind of model numbers on it or any other markings?
Old Apr 9, 2004 | 06:49 AM
dip-set's Avatar
Default Re: what car does this fit..? (95integraLS)
nah no model number on it,no markings...
Old Apr 9, 2004 | 08:22 AM
powerls's Avatar
it could be for an Integra, just a later one... I think they relocated or changed the brake resevoir, but I'm not sure what year they did it. So basically, I don't know jack
Old Apr 9, 2004 | 10:16 AM
dip-set's Avatar
Default Re: (powerls)
i believe it was 98+ they change over the reservior,and will fit those years..some one will chime in that knows hopefully..
Old Apr 15, 2004 | 10:04 AM
dip-set's Avatar
Default Re: (b18b-se)
still in need to know what car its for guys, so i can get rid of it...50.00 bucks shipped will take it..thanks
Old Apr 15, 2004 | 10:14 AM
Audi A4's Avatar
go around test fitting it ...
Old Apr 15, 2004 | 10:16 AM
Default Re: (DRAG lll INTEGRA)
Have you contacted neuspeed yet? Maybe they can tell you from a picture. Its worth a shot!
Old Apr 15, 2004 | 10:19 AM
H22A EG6's Avatar
Default Re: (95integraLS)
looks like the one i had on my old(1995) civic Si
Old Apr 15, 2004 | 10:59 AM
dip-set's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG lll INTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">go around test fitting it ...</TD></TR></TABLE>
lol i had that in mind..
Old Apr 15, 2004 | 11:00 AM
dip-set's Avatar
Default Re: (H22A EG6)
yeh it does look almost identical to that one which the tegs use also,i already have my new one installed...
Old Apr 15, 2004 | 11:01 AM
dip-set's Avatar
im trying that now,thanks,i should thought of that..
Old Apr 15, 2004 | 11:02 AM
Phatch99's Avatar
my brother has one that looks exactly like that on his car and its a 91 honda accord.
Old Apr 15, 2004 | 02:33 PM
Try2Live4God's Avatar
Default Re: what car does this fit..? (Phatch99)
Neuspeed seems to make bars that don't fit. I just recently got a Neuspeed lower rear tie bar for my '01 Integra and it doesn't clear cause of the ABS.
Old Apr 15, 2004 | 03:41 PM
Kendall's Avatar
Take a couple of measurements and call Neuspeed. They'll give you the exact information you're looking for.
Old Apr 15, 2004 | 05:06 PM
WhoisDan's Avatar
Default Re: what car does this fit..? (Try2Live4God)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Try2Live4God &raquo;</TD></TR><TR><TD CLASS="quote">Neuspeed seems to make bars that don't fit. I just recently got a Neuspeed lower rear tie bar for my '01 Integra and it doesn't clear cause of the ABS.</TD></TR></TABLE>
This problem occurs with most lower tie bars.
Old Apr 15, 2004 | 06:36 PM
Default Re: what car does this fit..? (whoisdan)
Which one's are common to give problems?
lv6l
Oct 9, 2006 10:15 PM
ragejed
May 7, 2004 05:08 PM
ActiveAero
Feb 20, 2003 06:32 AM
Dirt
Nov 21, 2002 09:33 AM
Mike P.
Nov 21, 2001 07:31 PM
