Couldn't get my HID's to work!!!!!!.....
Old Oct 26, 2001 | 07:04 PM
drosen55's Avatar
New User
Default Couldn't get my HID's to work!!!!!!.....
Hey, was wondering if somebody could shed some light on my current dilemma. I installed the Philips HID plug and play kit, but power didn't want to get to the ballasts for some reason. If anyone has installed this kit and could give me some info, all info would be greatly appreciated!!! Thank you very much. By the way, my car is a 2001 Civic Coupe.
[Modified by drosen55, 10:08 PM 10/26/2001]
Old Oct 27, 2001 | 02:38 PM
Ricehornet's Avatar
Default Re: Couldn't get my HID's to work!!!!!!..... (drosen55)
Check the headlight fuse in the driverside area of the dash. I suspect you have a blown fuse.
Old Oct 27, 2001 | 07:00 PM
Calavera's Avatar
Default Re: Couldn't get my HID's to work!!!!!!..... (Ricehornet)
And I believe you will need stronger fuses for those philips HID kits. The stock is 10amp(?), you need to upgrade to 15 or 20 amp(?) fuses for your low beam.
Old Oct 28, 2001 | 02:16 PM
EminemGSR's Avatar
Default Re: Couldn't get my HID's to work!!!!!!..... (Calavera)
A 15a fuse is good enough
Old Oct 29, 2001 | 08:49 AM
owen_the_soyboy's Avatar
make sure the plugs are not switched, like 180 degrees off.. because th epositive and negative is important.... that took me a few minutes to figure out that I plugged the headlight extension into the ballast wrong....!
the plug that goes from car electrical into the HID ballast.
EG-SIXV-TEC
Lighting
Mar 10, 2011 10:57 PM
EG-SIXV-TEC
Lighting
10
Jul 18, 2010 09:10 AM
gsrboy01
Apr 18, 2002 05:57 PM
damarksman
Sep 14, 2001 08:41 AM
