connecting rod bearing sizes for crower rods?
ummm, i believe that you buy your bearings when you measure your crank. of course if you resize your rods then it is a different story. this is all of course i think.... but i'm pretty sure. newbie choiboiracing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RAWB »</TD></TR><TR><TD CLASS="quote">I just got a set of ACL bearings- all my rods(Crowers) fit to the tee
Same here, Crowers with standard acl's and 100K+ crank, all clearances were fine.
</TD></TR></TABLE>Same here, Crowers with standard acl's and 100K+ crank, all clearances were fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importboi22 »</TD></TR><TR><TD CLASS="quote">arent the acl bearings the same thing as a honda green?</TD></TR></TABLE>
yep
yep
yep
</TD></TR></TABLE>is this actully true? what about the oversized acl bearings? what honda color would those be? does anyone know?
More like a brown...ACL's are .0790" Thickness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave »</TD></TR><TR><TD CLASS="quote">
More like a brown...ACL's are .0790" Thickness.</TD></TR></TABLE>
not rod bearings.
OEM rod bearings range from .0594 to .0586
OEM main bearings range from .0793 to .0783
not rod bearings.
