Chipped VSS gear in differential...:(
Old Oct 26, 2001 | 06:36 PM
boomslang's Avatar
Default Chipped VSS gear in differential...:(
I took apart my tranny to put my new Phantom Grip in. After I spent an hour taking apart the tranny and pulling the differential out, the shitty Phantom grip won't even fit. It is machined wrong, and won't let the pinion shaft in the differential pass through it, so it won't fit. I am getting a refund for the POS.
What is really making me angry is that I accidently slipped with the ball peen hammer and made a very small chip in the VSS gear on the diff. At least I think that is what the gear is. The chip is about 1mm x 1mm or so.
Think it will cause any problems with the functioning of the vss?
Old Oct 27, 2001 | 09:02 AM
Jared's Avatar
Default Re: Chipped VSS gear in differential...:( (Inlinefour)
chip won't make a difference as long as you didn't take a whole tooth out. btw, on those phantom grips, they make two models, one to fit the GSR/ITR type diff, and the other to fit the B16/LS type diff. you probably have the wrong one.
Old Oct 27, 2001 | 03:52 PM
Muckman's Avatar
Moderator in Chief
wrong model or not.. those "Phantom Grip" LSDs are really junk... You can tell by the name they gave it.. Sounds like it needs it own infomercial...
Old Oct 27, 2001 | 05:49 PM
Blown90hatcH's Avatar
Haha....those things are poop. Just invest in quaife. I am sure that you have the hook up price....if not let me know. The only things that I have seen been gained from those things....is a lot of wheel hop. Your VSS should be fine.
AaronEJ
Transmission & Drivetrain
Jan 31, 2013 12:00 AM
FreaQ
Mar 13, 2009 04:16 PM
EM2K20
Sep 9, 2008 08:52 PM
toddbenson
Dec 29, 2003 06:39 PM
boomslang
Oct 29, 2001 02:27 PM
