checking code on 98 accord
Old Apr 8, 2004 | 08:47 PM
Rob!'s Avatar
Default checking code on 98 accord
hey my friends accord has a check engine light on her 98 accord. how do you check the code? i looked on the passenger side kick panel but could not find the loose connector. can someone tell me how to pull the code without using a scanner. thanks
Old Apr 9, 2004 | 12:21 PM
Chiovnidca's Avatar
Default Re: checking code on 98 accord (EKsnatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKsnatchback &raquo;</TD></TR><TR><TD CLASS="quote">hey my friends accord has a check engine light on her 98 accord. how do you check the code? i looked on the passenger side kick panel but could not find the loose connector. can someone tell me how to pull the code without using a scanner. thanks</TD></TR></TABLE>
They don't have aservice check connector. You have to jump pins 4 and 9 of the data link connector.
Old Apr 9, 2004 | 04:40 PM
rabidcat53's Avatar
If you pick up a Haynes manual, in chapter 6 it tells how to jump the pins and read the code. I'll share that info later, when my book and car returns home tomorrow.
Bigdingo74
Mar 26, 2019 04:03 PM
98honda51
Dec 31, 2016 05:31 PM
joebudd
Jun 26, 2007 01:12 PM
ssiruuk60
Jun 15, 2007 04:57 PM
hondaracer4vtec
Jan 28, 2006 12:36 PM
