99-00 Si Spoiler Size
Old Apr 8, 2004 | 08:07 PM
Vero's Avatar
Default 99-00 Si Spoiler Size
Anyone have a chart or measurements showing how long and wide the 99-00 Si wing is at the base (mount points)?
Also would it mount up in the same holes used on a 96-98 ex wing?
Always appreciated.
Old Apr 8, 2004 | 09:11 PM
Padawan's Avatar
Darth ModerVader
Default Re: 99-00 Si Spoiler Size (Vero)
If no one has any information by tomorrow, I'll go out and measure the one laying around in our garage.
Old Apr 8, 2004 | 09:14 PM
pdiggitydogg's Avatar
I know it matches the other civic's holes just fine
as for the rest...Its too cold and late for me to run out and measure
Old Apr 8, 2004 | 09:34 PM
Vero's Avatar
thanks guys
Old Apr 8, 2004 | 09:37 PM
JDM-EJ1's Avatar
Default Re: (pdiggitydogg)
Hummm... So would one fit my 94 EX? I have the smaller spoler that came on the 92-98 models I believe.
Old Apr 9, 2004 | 06:55 AM
Vero's Avatar
bump for the morning.
Old Apr 9, 2004 | 07:08 AM
Padawan's Avatar
Darth ModerVader
Default Re: (SlammedSi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedSi00 &raquo;</TD></TR><TR><TD CLASS="quote">Hummm... So would one fit my 94 EX? I have the smaller spoler that came on the 92-98 models I believe.</TD></TR></TABLE>
'92-'95 Civics were a completely different body style, and used different spoilers, so it's doubtful that it would fit.
Old Apr 9, 2004 | 09:00 AM
Padawan's Avatar
Darth ModerVader
Default Re: (Vero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vero &raquo;</TD></TR><TR><TD CLASS="quote">bump for the morning.</TD></TR></TABLE>
Measurements as promised from '99 OEM spoiler:
Note - "Front" means closest to front of car, "Rear" means closest to rear (obvious, I know). All measurements taken from bolt centers.
Distance between left and right <u>front</u> bolts: 46-3/16"
Distance between left and right <u>rear</u> bolts: 46"
Distance between front and rear bolt (either side): 1-3/8"
Distance between <u>front</u> bolt and front edge of spoiler's base: 4-5/8"
Distance between <u>rear</u> bolt and rear edge of spoiler's base: 2-1/2"
Old Apr 9, 2004 | 09:16 AM
Formula 1's Avatar
Default Re: (Padawan)
i dunno free bump
on a side note i dont like spoilers on EKs especially coupe
Old Apr 9, 2004 | 10:07 AM
Vero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
Distance between <u>rear</u> bolt and rear edge of spoiler's base: 2-1/2"</TD></TR></TABLE>
Thats great, how about width on each side of the mounts?
Old Apr 9, 2004 | 10:23 AM
Padawan's Avatar
Darth ModerVader
Default Re: (Vero)
You mean the distance from the bolts to the sides of the mounting surface?
Old Apr 9, 2004 | 10:29 AM
Vero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">You mean the distance from the bolts to the sides of the mounting surface?</TD></TR></TABLE>
if you look at it from the top the
| = side of car
[] = where the spoiler lays on the car.
_____ = seperatation
|[]______[]|
how long and wide is []
Old Apr 9, 2004 | 10:33 AM
Padawan's Avatar
Darth ModerVader
Default Re: (Vero)
Give me a few minutes and I'll sketch up a make-shift diagram for you.
Old Apr 9, 2004 | 11:37 AM
Padawan's Avatar
Darth ModerVader
OK, here it goes...
Photo of the actual spoiler. I painted the bolts with Wite-Out so they'd show up better:
My fancy diagram. Dimensions are lettered, and the key is below:
A: 46"
B: 47-7/8"
C: 1-3/8"
D: 46-3/16"
E: 46"
F: 9/16" (distance between center of bolt and outer edge of mounting surface
Some dimensions that I forgot to draw on the diagram:
Width of each mounting surface at widest point = 3"
Distance from <u>rear</u> bolt to <u>rear</u> edge of mounting surface = 2-1/2"
Distance from <u>front</u> bolt to <u>front</u> edge of mounting surface = 4-5/8"
Old Apr 9, 2004 | 12:20 PM
Vero's Avatar
Thank you good sir, that is just what I needed to know.
Hopefully what I want to do, I will be able to thanks to this.
Old Apr 9, 2004 | 12:28 PM
H22A EG6's Avatar
very nice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">OK, here it goes...
A: 46"
B: 47-7/8"
C: 1-3/8"
D: 46-3/16"
E: 46"
Distance from <u>front</u> bolt to <u>front</u> edge of mounting surface = 4-5/8" </TD></TR></TABLE>
92d15b7
Aug 11, 2010 06:33 PM
94_civicEx
Jan 28, 2007 03:30 PM
DXH
Oct 1, 2006 08:19 PM
NitroSign
17
Jul 21, 2005 07:58 PM
KillaB18
Apr 6, 2005 09:01 PM
