Type R valvespring question
Old Oct 26, 2001 | 04:36 PM
ToneyTigre's Avatar
New User
Default Type R valvespring question
Im planing to put in a set of CTR cams and raise my rev limiter to 86K. will it be safe to just use the ITR inner valve springs with my stock Si outer springs and avoid valve float at 8600 rpm?? i also have the ITR retainers. need to know asap. thanks
[Modified by ToneyTigre, 10:02 PM 10/26/2001]
Old Oct 26, 2001 | 07:48 PM
rainforest's Avatar
Default Re: Type R valvespring question (ToneyTigre)
yep it will be ok.
Old Oct 26, 2001 | 09:04 PM
ToneyTigre's Avatar
New User
Default Re: Type R valvespring question (rainforest)
just curious, what are the ITR retainers made from? is it titanium?
Old Oct 26, 2001 | 10:48 PM
sgT's Avatar
sgT
You will want the itr OUTER intake valvesprings.
And yes you will want the inner springs on all 16.
ITR retainers are same as other b-series. steel.
Old Oct 28, 2001 | 11:53 AM
ToneyTigre's Avatar
New User
Default Re: Type R valvespring question (sgT)
so you think theres gonna be valve floating at 8600 rpm. with ITR inner spring and retainer with my stock Si outer springs? i only wanna upgrade to CTR cams and ITR ecu...
aiya! i have two conflicting infomation... anybody elsehave theories?? i really dont wanna spend another $160 on outer springs if i dont have to.
Old Oct 28, 2001 | 02:55 PM
BoostinDC2's Avatar
why dont u just get some JUN or TODA springs
Old Oct 28, 2001 | 03:08 PM
rioninja's Avatar
Default Re: Type R valvespring question (BoostinDC2)
Maybe you didnt read the posts. Why do you think? -----> $$$ <-----
Thats why.
Old Oct 28, 2001 | 04:47 PM
lazyvietboi's Avatar
Default Re: Type R valvespring question (RioNinja)
are skunk2 valvespring good?
Old Oct 28, 2001 | 09:04 PM
ToneyTigre's Avatar
New User
Default Re: Type R valvespring question (lazyvietboi)
ya.. i wish i could get toda... but ya, im on a budget. so will I get valve float with that set up?
Old Oct 31, 2001 | 08:05 PM
ToneyTigre's Avatar
New User
anyone else?
Old Nov 1, 2001 | 12:43 PM
Screamer's Avatar
Yes use the OUTER ITR springs and it should be fine. If you have a bit of cash to spear buy some portflow inners and you can rev it up to 9500rpm that's what I am using with my Jun 3's.
Baron55
Jan 15, 2007 04:57 PM
roadawg
Jan 27, 2004 01:48 PM
genetsang
Jun 9, 2003 01:11 PM
pistol
Apr 17, 2002 09:49 PM
Timmayeg
Mar 15, 2002 11:25 AM
