are all d series clutch(PP)/flywheel the samething???
Old Apr 8, 2004 | 04:24 PM
SPOON_BeIgHtEeNsEe's Avatar
Default are all d series clutch(PP)/flywheel the samething???
i have a act clutch/flywheel off a 88-91 crx si... i was wondering if i could use the Pressure Plate and the flywheel on my d16y7 block??? and just buy a new clutch disc since the one with the PP doesnt fit... or do i have to get one for my year?
Old Apr 8, 2004 | 04:29 PM
sohcvtec1995's Avatar
Default Re: are all d series clutch(PP)/flywheel the samething??? (SPOON_BeIgHtEeNsEe)
i am pretty sure. Unless it being a cable tranny clutch and your putting it in a hydro one
Old Apr 8, 2004 | 04:31 PM
carsaregood's Avatar
i'm pretty sure as long as you use the same flywheel/clutch disk/pressure plate, it will work (if its not a 21 spline disk).
http://www.gamesbbs.com/~dmoore/tranny.htm
88' has 190mm flywheel/disc, 21 spline
89' 200 mm, 20 spline
90-(00' ??) 212 mm, 20 spline.
so anyway, you can use any 89 and up set, unless you're running an 88, 21 spline tranny.
Old Apr 8, 2004 | 04:57 PM
Default Re: are all d series clutch(PP)/flywheel the samething??? (carsaregood)
well the clutch and flywheel was from a cable tranny... im gonna be putting it in a z6 hydro tranny... the disc wont work cause i try to fit it in the tranny lastnight and wouldnt go in... but i wanted to know if i could still use the flywheel, Pressure plate and just buy a new clutch disc...
Old Apr 8, 2004 | 07:54 PM
you might be able to. count the splines in the clutch disc, and measure the clutch disc diameter. if you count 21 splines, you can't get a replacement disk that would work, because the only 21 spline disk is 190 mm, which would also be the diameter of the mating surface of your flywheel and pp. if its 20 spline, you can use it, just get the correct size disk for your pp/flywheel.
Old Apr 9, 2004 | 11:58 AM
yeah ill probably just buy a new clutch... but what about the flywheel..??? will it still work?
Old Apr 9, 2004 | 12:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOON_BeIgHtEeNsEe &raquo;</TD></TR><TR><TD CLASS="quote">the disc wont work cause i try to fit it in the tranny lastnight and wouldnt go in... but i wanted to know if i could still use the flywheel, Pressure plate and just buy a new clutch disc... </TD></TR></TABLE>
ok, since the clutch disk doesn't go on the tranny splined shaft, that means its a 21 spline, meaning its for an '88 tranny, meaning that the disk is 190 mm diameter, and so are the flywheel/pressure plate contact surfaces.
you can't use any of it, unless you decided to use an '88 cable tranny, which would be more trouble than its worth.
if the set was from ANY other year, '89 and up, you would be able to use it.
Old Apr 9, 2004 | 12:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOON_BeIgHtEeNsEe &raquo;</TD></TR><TR><TD CLASS="quote">yeah ill probably just buy a new clutch... but what about the flywheel..??? will it still work?</TD></TR></TABLE>
the flywheel won't work because its 190 mm across, and only an '88 clutch disk has that diameter, but that disk won't go on your tranny.
Old Apr 9, 2004 | 05:34 PM
**** u for real... so i bought this crap for nothing... yeah i wont be using a cable tranny i just put way to much money into my lsd z6 tranny... well does anyone want a act clutch and flywheel...???
Old Apr 9, 2004 | 06:01 PM
ok i went onto act site... and looked up the part number on the box of the flywheel... PN# 600120 thats what it says on the box... and on the site it says its for 92-01 civics http://www.advancedclutch.com/...t=708
Old Apr 9, 2004 | 06:40 PM
hm, i guess its possible that the person who had the flywheel/clutch/pp combo was using an 88 tranny, and 190mm disk, but with a bigger flywheel.
did you ever measure ?
Old Apr 9, 2004 | 07:10 PM
sloweredcivic's Avatar
88 is the only odd ball year i know the feeling i baught a tranny that the guy swore came out of a 91 and gat a 88 si tranny that i still have for sale how much would you want for the clutch and flywheel setup? i might pick it up so i could use the tranny thanks
LsVtec08
Transmission & Drivetrain
Jan 4, 2011 06:59 PM
2muchPSI
Jan 23, 2003 09:06 AM
thecorey
Sep 27, 2002 03:03 PM
